    +d% - WTF?! [SOLVED](for now...)
    8 Posts 5 Posters 654 Views 5 Watching
    • K Offline
      KXI System
      PROBLEM SOVLED
      For now...
      Ok, so I tried opening my Sketchup and this popped up:
      Help! 😲
      Getting the perfect sig is hard...
      Google it!
        Jim
        Did you install any plug-ins recently?
        • K Offline
          KXI System
          Not in the past week no, actually not at all.
          Google it!
            Search your plugin folder for files that contains "%d more".
            • K Offline
              KXI System
              I'll try that...
              But its not there!
              Google it!
                chrisjk
                I think it has served you well so far and is asking for a tip! 😄
                Chris
                  You need to have a decent search tool to look inside rubies - the PC's own doesn't look in .rb files properly.
                  Try getting baregrep [free], then search all .rb Plugins recently installed [by date] for 'more' or '%d' or '%d more' or UI.messagebox or UI::messagebox... Search sub-folders too as it might be in there...
                  If some ijit has used variables to build up a string it'll be harder to find - if it's been compiled into a .rbs file then eeek!... Then you'll need to remove the scripts in blocks [by date?] systematically till it stops the error - then add them back in 'halves' until it breaks again - then you can find you find the culprit in the ever decreasing number of files 128/64/32/16/8/4/2/1 etc...
                  • K Offline
                    KXI System
                    Its ok guys, I started my PC today and SU worked fine.
                    If I still got this problem I'll bump this thread.
                    Google it!
