    Architects & Engineers for 9/11 Truth
    95 Posts 27 Posters 5.9k Views 27 Watching
    • BoxB Offline
      @tomot said:
      Which raises the question about the the use of termite,
      Highly trained Ninja Termites? 🤣
      • andybotA Offline
        andybot
        I think Pete left that one out of his funny pics post... 😆
        • Alan FraserA Offline
          Alan Fraser
          That's quite a well known picture of the column. There is no provenance for when it was taken. Truthers will have you believe it was immediately after the collapse...but there is no evidence for that. It could equally (in fact far more likely) have been taken days afterwards when the rescue and clear-up was well under way. Many such columns were then cut by oxy-acetylene in exactly that manner in order to create more manageable chunks for removal.
          3D Figures
          • HieruH Offline
            Hieru
            There is a wider shot showing what looks like oxyacetylene equipment nearby.
            It's dirty tricks like this - and harassing members who don't toe the party line - that makes a mockery of AE911. Worse still it gets in the way of learning anything valuable from this tragedy.
            www.davidhier.co.uk
            • jeff hammondJ Offline
              jeff hammond
              @andybot said:
              my main point of contention is that the explosives and the planes crashing would have to be coordinated to some degree. That would point to a broader conspiracy.
              speaking of coordination...
              sort of interesting to think about why the buildings were hit/collapsed in that order (wtc1 hit first fell 2nd)
              why did the demo engineer(s) time it in such a manner? you would naturally think that the 1st one hit would also fall first.. so they made a conscious decision to flip flop the sequence.. just curious as to why.. and why so late with wtc7? or maybe it was technical difficulties?
              (*of course, all this assumes the buildings were brought down as a demolition instead of solely being an airstrike 😉 )
              but leaving building 7 up for so long while it was rigged with explosives is just plain stupid of the engineers.. there's no way they could of been able to guarantee control of the building that day.. leaving it up so long left too much of a chance that their explosives etc would of been found by someone.
              dotdotdot
              • bmikeB Offline
                bmike
                i mean really.. what would it take? a group of 4 or 5 guys with proper security clearance working for a month or two? it's not that farfetched.
                not any more farfetched than 20 guys learning how to fly commercial jets over a period of 3-4 years then hijacking them with box cutters and driving them into a few buildings..
                both stories, to me, are just as likely to occur.
                It's not like there wasn't already a plan to do some terrorism and blame it on Cuba...
                One of the most fascinating aspects of Operation Northwoods involved the proposed hijacking of an American passenger plane. The JCS proposed that a real plane containing American passengers would be hijacked by friendly forces disguised as Cuban agents. The plane would drop down off the radar screen and be replaced by a pilotless aircraft, which would crash, purportedly killing all the passengers. Under the plan, the real passenger plane would be secretly flown back to the United States.[14]
                Operation Northwoods - Wikipedia
                (en.wikipedia.org)
                mike beganyi design + consulting llc
                  tomasz
                  I wouldn't cut it this way, if I would be asked to. Would you? The length of the cut is ca. 1.6 greater when a width of the column. It wouldn't be safe either. It is a standard way one would position steel cutting charges to remove vertical resistance of the column.
                    Alan Fraser
                    So now you're a demolition expert too? presumably you'd cut horizontally, so you would have no control over which way it fell? Don't apply for a job as a tree surgeon.
                    I also can't understand this fascination with thermite. Truthers bandy it about like it was some kind of magic bullet. As TIG has already explained, it's just a simple chemical reaction that happens to be exothermic.
                    It's not even a low explosive, much less a high explosive; it's an incendiary. It generates a lot of heat...that's it. It's just as likely to weld stuff together as cut it apart. In fact that's been its primary use for over a century...welding lengths of rail track together.
                    Not being an explosive, it takes its own sweet time about severing anything. Also, not being an explosive, you'd need tons of the stuff...literally....on every floor. The notion that this would be used in what needs to be a split-second-perfect controlled demolition in preference to much more portable shaped charges that send a stream of vaporised copper instantly slicing clean through the columns is beyond absurd.
                    Truthers have posted a clip on YouTube showing a directed thermite ignition instantly severing a steel rod. However, they conveniently overlook the size of the necessary containment vessel compared to the thickness (or lack of) of the steel rod. Scale this up and you'd need something the size of a truck strapped to every column.
                    Its akin to suggesting that all those elaborate fountain displays you see in places like Vegas don't need computer controlled hydraulic systems but would work much better if you employed a few guys with millions of Coke bottles and a truck load of Mentos.
                    There is a cloud of utter incompetence surrounding 9/11...before, during and after. This is standard SNAFU for any government. It was exactly the same leading up to Pearl Harbor...which should have come as no surprise to anyone. I guess it's just a sign of the times (and the legacy of many, many Hollywood movies involving nasty NSA characters) that there were no such cries of "Conspiracy!" in 1941.
                    I'm surprised they haven't already made a movie about how FDR knew what was going down but supressed the information in order to create an excuse to get the USA into the war...maybe they have; and it went straight to video. You can't keep a good rumour-mill down.
                    3D Figures
                      tomasz
                      One doesn't have to be a demolition expert to know how to cut such a heavy thing to get it slide vertically.
                      Cutting it the way it is shown wouldn't give you much more control then cutting it horizontally. No one would start the job without an assistance of a crane anyway.
                      Check the document starting from 1h 33m . They dsicovered the presence of nano-thermite in debris and explain differences between thermite and its modern version. This is a material of military use which really shouldn't be there.
                        These self-appointed experts call it 'nano-thermite'... but naming something doesn't make it that thing.
                        They admit it's mainly aluminum and iron-oxide, mixed with other stuff like carbon, but that would have resulted from the catastrophic happenings and does not mean it was manufactured elsewhere.
                        There was undoubtedly molten metal present on the impacted floor-plates before the major collapse and the pulverization. It could have been a molten aluminium and iron/rust mixture.
                        Spraying this molten material into a fine aerosol [by 'explosive' collapse], mixed with a dust from other building-materials, it could coalesce in small 'droplets' of combined materials, giving this similar appearance [e.g. has anyone replicated this process; how is 'real' nano-thermite made etc].
                        I do not think that they have demonstrated this is 'military-grade' lab-made explosive called 'nano-thermite'.
                        It might contain many of the same components, but could have be made in several 'natural' ways.
                        The Danish chemist makes an unacceptable 'leap of assumption'.
                        He effectively says this is 'explosive' because the building was 'blown up' [...as (his) other 'evidence' shows...].
                        Where were the comparative microscopic images of this 'dust' and bits of 'real' nano-thermite ?
                        If they existed and were to be all but identical it would be a lot more convincing.
                        Sayings it's so doesn't make it so, without proof.
                        The chemist starts off with '[this dust]...is something we characterize as...', within a few seconds of edits it is 'thermite' - then it is 'nano-thermite'.
                        There is no proper proof offered as to its provenance or it's exact equivalence.
                        This is not science, it's unsubstantiated opinion [like mine 😉 ]
                        I feel this misinformation is almost intended to obscure the real issues about official incompetence, before, during and after the tragic events of 9/11. Many things were done wrongly or inappropriately, but that does not mean there was a single conspiracy - perhaps there were several mini-conspiracies after the events, intended to cover arses; but concluding that there were such wicked acts like 'deliberate demolition' does not follow from the 'real' evidence. There are undoubtedly many weird and puzzling things about the events, adding these extra layers of obscurantism does nothing to help us try to understand what really happened...
                          Here's some rebuttals and interesting links http://www.cracked.com/article_15740_was-911-inside-job.html
                          http://www.debunking911.com/
                          • StinkieS Offline
                            Stinkie
                            Sums it up rather nicely.
                              Here's an alternative theory about molten aluminum reacting with water from the sprinklers and releasing hydrogen gas which then burns very hot/explodes and affects the steelwork etc...
                              http://www.youtube.com/watch?v=ftncKDv4JMs&feature=related
                                jeff hammond
                                broadening out some..
                                so, say you found definitive proof that 9/11 was a false flag attack… rummy & co. planned/coordinated/executed it and everyone knows it..
                                now what?
                                is anything going to change? (i mean- really change.. not just some reshuffling of personnel and maybe some jail time or death penalty for a couple of people)
                                would we all of a sudden have a "no sociopaths allowed in politics" policy?
                                it seems the only thing these people that are dedicating their lives to finding 911truth will actually accomplish, should they prove to be correct, is the right to walk around saying "see, i told you so!" …meanwhile, it's business as usual for the powers that be..
                                dotdotdot
                                • bmikeB Offline
                                  bmike
                                  agreed. business as usual.
                                  from fight club:
                                  "We're consumers. We are by-products of a lifestyle obsession. Murder, crime, poverty, these things don't concern me. What concerns me are celebrity magazines, television with 500 channels, some guy's name on my underwear. Rogaine, Viagra, Olestra."
                                  remember - after 9/11 bush told everyone to 'go shopping'.
                                  not to suck it up and sacrifice to bring the criminals to justice (who ever they were).
                                  not a call to arms for a draft or for good men and women to join the armed forces, coast guard, police.
                                  no, we were told to 'go shopping'.
                                  otherwise our precious economy could slump, and people would be out of work. and retirement accounts would dry up. and the market wouldn't perform for investors.
                                  then people would be out of money. tight on budget. maybe lose their homes.
                                  and people wouldn't be so blinded by the consumerism.
                                  the next shiny thing on sale.
                                  folks lie to their kids about santa claus, the easter bunny, jesus, god, and all the rest.
                                  i don't find it a leap that it would be easy for someone to let some intelligence slide through.
                                  to then let some folks take advantage of that to go to war. or push through new legislation. or just be able to play with some new toys.
                                  people do it all the time. husbands lie to their wives about what they do on business trips. ministers lie about being gay. a fib here. an outright lie there.
                                  its all human nature played out on a grand scale.
                                  its not crazy to think that there are those spooky NSA types out there. operation northwoods, questions regarding pearl harbor (who knew what, and when - and oddly - that there was an exercise going on at the time so radar was picking up the flight of b17s and not the japanese), the ghost ships in the gulf on tonkin, the sinking of the uss maine firming up involvement the spanish american war, wmds in iraq, misleading information propagated by celebrities about immunizations, hitler burning the reichstag to seize power. caesar being assassinated. climate change.
                                  it goes on and on. the scales change. the characters change.
                                  but we keep fucking with each other.
                                  lying, killing, profiting, cheating.
                                  for what - i don't know.
                                  regardless of whodunit, and why, the world has changed.
                                  we now have the TSA, wiretapping of US citizens (with corporate buy in to let the NSA do it).
                                  2 wars. thousands? hundred of thousands dead.
                                  billions of dollars spent.
                                  thousands of soldiers returning home without proper medical care and mental health care.
                                  tens of thousands (hundreds of thousands) of lives ruined in iraq and afghanistan.
                                  and an environment where the US government can kill a US citizen with a secret letter - sending a drone to wherever you might be, without a trial, with no cause, with no way for you to face your accusers.
                                  but, there are fun shiny things.
                                  i'm off to boing boing to see some awesomeness.
                                  mission accomplished.
                                  and, FWIW, i think both sides of this debate have value. the truthers are as nuts as the believers. the reality lay somewhere in the cloudy middle.
                                  • 5 / 5
