    SketchUp versions of Arroway Textures
    25 Posts 10 Posters 8.5k Views 10 Watching
    • Al HartA
      Al Hart
      Arrow Textures has a sampler pack Textures Edition One
      They make the low-res versions of these textures available at no cost - for both commercial and non-commercial use.
      I have created a SketchUp Texture Collection based on these textures. I would be interested to know if these textures (without bump and specular maps) are of any value to SketchUp users?
      If you have a third party renderer, you can download the full texture set for each texture from Arroway. (Or purchase the high res versions) and use them to render these textures.
      Give them a try: Arroway Texture Set
      If you unzip this into C:\Program Files\Google\Google SketchUp 7\Materials they should just work.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • R
        rdluther
        Thanks Al these are going to be great!
        • D
          d12dozr
          Thanks, Al...very useful!
          http://goo.gl/f7ooYh
          • M
            miikka1978
            Thanks. These are perfect for my needs.
            • M
              meak
              thanks
              • K
                kwistenbiebel
                Thank you al. This is useful. Much and much better than the default SU material library.
                • GaieusG
                  Yes, definitely. Even good for (not too close-up) renderings.
                  But special thanks Al for clarifying that they can (now) be used in commercial projects (although they would obviously take it as courtesy if one bought them for this purpose).
                  • Al HartA
                    Al Hart
                    I see I messed up the names a bit - I will make a new set tomorrow. These will work just fine, except for the names.
                    Let me see some of the models you create.
                    Al Hart
                    • GaieusG
                      yes, the names would be essential as the bump and specular maps need to match so that people can find them easily from thumbnails...
                      • Al HartA
                        Al Hart
                        Here is one of the typical names now:
                        stone-002_Arroway-lo-res-Arroway-low-res
                        It is usable, but it it would be better if it was
                        Which is what I intended.
                        The stone-002 is the important part, since it matches Arroway's terminology
                        Al Hart
                        • TIGT
                          To neb in...
                          I have a very quick batch filename fixer 'Lupas Rename' and I've already fixed all of my .skm's to suit... BUT it's 24Mb zipped - so how did you 'upload' such a big file onto the forum in the first place ? I see it's linked back - do you want me to email you a copy - my limit is email 20Mb but I can split it... ? 😕
                          • Al HartA
                            Al Hart
                            @tig said:
                            To neb in...
                            Thanks for the offer:
                            I renamed one of the .SKM files, but it still shows up with the funny name when I browse for materials in SketchUp in "List" mode.
                            I see that the name of the material is also contained in the .XML files which are zipped into the .SKM file:
                            document.xml: <mat:material colorBlue="121" colorGreen="137" colorRed="143" colorizeType="0" hasTexture="1" name="boards-001_Arroway-lo-res-Arroway-low-res" trans="0.5" type="1" useTrans="0">
                            documentProperties.xml: dp:titleboards-001_Arroway-lo-res-Arroway-low-res</dp:title>
                            Does your script alter the .XML files as well?
                            If not, then it would be better if I recreate them.
                            (The .ZIP file is stored on another web site, and only linked to in the original post.)
                            Al Hart
                            • TIGT
                              I see the problem - sorry but needs to be done from scratch to get the innards right... 😢
                              • Al HartA
                                Al Hart
                                I have uploaded a new version, with better names. Arroway Texture Set
                                If you have already downloaded the old version, you will want to remove the Arroway folder in
                                Al Hart
                                • GaieusG
                                  Hi Al,
                                  I finally got to downloading the whole pack (and thanks again).
                                  However it seems that under the "Plasters" folder, there are no materials. Did you just miss them or weren't the materials available for download in free/low-res version?
                                  • Al HartA
                                    Al Hart
                                    @gaieus said:
                                    Hi Al,
                                    I made all those categories myself by saving the materials from SketchUp and saving them as a collection, and then moving all the materials into sub-folders. The plasters are all under Masonry, if you want to move them.
                                    Al Hart
                                    • GaieusG
                                      Okay, thanks! 👍 That makes sense and of course, I can arrange them as I wish.
                                      • Al HartA
                                        Al Hart
                                        Let me know if these work for you, and I would love to see an image up here on the forum if you have anything to show.
                                        We are also going to market a full resolution version of these 100 materials, along with the bump and specular maps for use with 3rd party rendering engines, for about $100.00 if anyone is interested. (You can purchase the full texture pack from Arroway for less money, but some people may be willing to pay a few $$ more for a SketchUp ready (and, of course, IRender nXt ready) version of the high res textures.)
                                        Al Hart
                                        • A
                                          awhale
                                          Any chance these texture collections are still online somewhere? The links you posted are now dead.
                                          Thanks!
                                          • Al HartA
                                            Al Hart
                                            I found and uploaded the original file arroway.zip to
                                            Arroway.zip
                                            However, it seems to have the "double" file names.
                                            Gaieus, or anyone else, if you have a copy of the file with the corrected file names, send it to me (a 24 meg email is no problem), and I will upload it instead. (al.hart AT renderplus.com)
                                            Al Hart
