    SketchUp versions of Arroway Textures
    25 Posts 10 Posters 7.9k Views 10 Watching
      d12dozr
      Thanks, Al...very useful!
      http://goo.gl/f7ooYh
        miikka1978
        Thanks. These are perfect for my needs.
          meak
          thanks
            kwistenbiebel
            Thank you al. This is useful. Much and much better than the default SU material library.
              Yes, definitely. Even good for (not too close-up) renderings.
              But special thanks Al for clarifying that they can (now) be used in commercial projects (although they would obviously take it as courtesy if one bought them for this purpose).
              • Al HartA Offline
                Al Hart
                I see I messed up the names a bit - I will make a new set tomorrow. These will work just fine, except for the names.
                Let me see some of the models you create.
                Al Hart
                IRender nXt from Render Plus
                  yes, the names would be essential as the bump and specular maps need to match so that people can find them easily from thumbnails...
                  • Al HartA Offline
                    Al Hart
                    Here is one of the typical names now:
                    stone-002_Arroway-lo-res-Arroway-low-res
                    It is usable, but it it would be better if it was
                    Which is what I intended.
                    The stone-002 is the important part, since it matches Arroway's terminology
                    Al Hart
                      To neb in...
                      I have a very quick batch filename fixer 'Lupas Rename' and I've already fixed all of my .skm's to suit... BUT it's 24Mb zipped - so how did you 'upload' such a big file onto the forum in the first place ? I see it's linked back - do you want me to email you a copy - my limit is email 20Mb but I can split it... ? 😕
                      • Al HartA Offline
                        Al Hart
                        @tig said:
                        To neb in...
                        Thanks for the offer:
                        I renamed one of the .SKM files, but it still shows up with the funny name when I browse for materials in SketchUp in "List" mode.
                        I see that the name of the material is also contained in the .XML files which are zipped into the .SKM file:
                        document.xml: <mat:material colorBlue="121" colorGreen="137" colorRed="143" colorizeType="0" hasTexture="1" name="boards-001_Arroway-lo-res-Arroway-low-res" trans="0.5" type="1" useTrans="0">
                        documentProperties.xml: dp:titleboards-001_Arroway-lo-res-Arroway-low-res</dp:title>
                        Does your script alter the .XML files as well?
                        If not, then it would be better if I recreate them.
                        (The .ZIP file is stored on another web site, and only linked to in the original post.)
                        Al Hart
                          I see the problem - sorry but needs to be done from scratch to get the innards right... 😢
                          • Al HartA Offline
                            Al Hart
                            I have uploaded a new version, with better names. Arroway Texture Set
                            If you have already downloaded the old version, you will want to remove the Arroway folder in
                            C:\Program Files\Google\Google SketchUp 7\Materials
                            Al Hart
                              Hi Al,
                              I finally got to downloading the whole pack (and thanks again).
                              However it seems that under the "Plasters" folder, there are no materials. Did you just miss them or weren't the materials available for download in free/low-res version?
                              • Al HartA Offline
                                Al Hart
                                @gaieus said:
                                Hi Al,
                                I made all those categories myself by saving the materials from SketchUp and saving them as a collection, and then moving all the materials into sub-folders. The plasters are all under Masonry, if you want to move them.
                                Al Hart
                                  Okay, thanks! 👍 That makes sense and of course, I can arrange them as I wish.
                                  • Al HartA Offline
                                    Al Hart
                                    Let me know if these work for you, and I would love to see an image up here on the forum if you have anything to show.
                                    We are also going to market a full resolution version of these 100 materials, along with the bump and specular maps for use with 3rd party rendering engines, for about $100.00 if anyone is interested. (You can purchase the full texture pack from Arroway for less money, but some people may be willing to pay a few $$ more for a SketchUp ready (and, of course, IRender nXt ready) version of the high res textures.)
                                    Al Hart
                                      awhale
                                      Any chance these texture collections are still online somewhere? The links you posted are now dead.
                                      • Al HartA Offline
                                        Al Hart
                                        I found and uploaded the original file arroway.zip to
                                        Arroway.zip
                                        However, it seems to have the "double" file names.
                                        Gaieus, or anyone else, if you have a copy of the file with the corrected file names, send it to me (a 24 meg email is no problem), and I will upload it instead. (al.hart AT renderplus.com)
                                        Al Hart
                                        • KrisidiousK Offline
                                          Krisidious
                                          Thanks... looking forward to the final version.
                                          By: Kristoff Rand
                                          • Al HartA Offline
                                            Al Hart
                                            The ones I uploaded should work - they just have funny names.
                                            Al Hart
