    Erasing a face
    4 Posts 3 Posters 339 Views 3 Watching
    • T
      toolmaker23
      I'm drawing a cabinet, which has 3 shelves in it. When I close in the geometry to create the shelves, it also creates a face on the back of the cabinet between the shelves, which blocks the view into the cabinet, is there away I can erase the face. I am fairly new at this, but as a toolmaker, I do have experience with 3D drawing and programming, and am having a great time with this software. Thanks for your help ❓
      • K
        Khai
        click on the face to select it then press the Delete key πŸ’š
          Use 'Select' tool (spacebar) to select the face and press delete key
          or
          right click face with 'Select' tool and choose 'Erase'
          or
          hover over face with 'Move' tool (m) and press delete
          as you can see there are many ways to erase faces but there is also many ways to prevent the face that you gonna delete from appearing in the first place
          if you are new to this I'd recommend Aidan Chopra's YouTube Channel as your first Pitstop. Then I suggest to get his book 'SU for Dummies.
          Finally post your problems here as there are great advisors and a friendly community
          • T
            toolmaker23
            Many thanks for the quick replies, it worked like a charm, I had been fighting this problem for a while. I'm sure I will have other issues to deal with, as I learn more, but I will be looking for the answers here. I did take a quick look at the Aidan Chopra Tutorials on You Tube & they look very helpful, I guess I'll have to break down and buy the Dummies book too. πŸ˜„
