    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 802.3k Views 175 Watching
      By popular request here are all of the Extrude Tools [current versions at the file's date-code] all collected into one RBZ archive.
      [flash=700,500:2ay9zx65]http://www.youtube.com/v/0lmLHyhTIBM[/flash:2ay9zx65]
      Donations:
      Are welcome by PayPal.com = info @ revitrev.org PayPalButton
      The links to the tools' threads, containing explanations and notes etc are:
      ExtrudeEdgesByEdges http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
      ExtrudeEdgesByLathe http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
      ExtrudeEdgesByRails http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
      ExtrudeEdgesByVector http://forums.sketchucation.com/viewtopic.php?p=216977#p216977
      Note: from 20100212 the EEby... these scripts can only be downloaded from this thread in the archive set found below...
      Two new tools added 20100212...
      ExtrudeEdgesByFace http://forums.sketchucation.com/viewtopic.php?p=224218#p224218
      ExtrudeEdgesByRailsByFace http://forums.sketchucation.com/viewtopic.php?p=224219#p224219
      New tool added 20100219...
      ExtrudeEdgesByFaces http://forums.sketchucation.com/viewtopic.php?p=226249#p226249
      New tool added 20100309...
      ExtrudeEdgesByLoft http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
      New tool added 20100428
      ExtrudeEdgesByRailsToLattice http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
      New tool added 20110524 and 20110525
      ExtrudeEdgesByVectorToObject http://forums.sketchucation.com/viewtopic.php?p=331059#p331059
      ExtrudeEdgesByOffset http://forums.sketchucation.com/viewtopic.php?p=331303#p331303
      Two tools now have 'Quad Faces' options to complement Thomthom's Quad-Tool
      20111003/04
      20111020 update includes new ES lingvo files and a minor db correction to EEbyLathe
      20111023 update now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
      20111102 update EEbyLathe - Fixed Picked-Angle's messy undo. Smoothed-edges now stop @90ΒΊ.
      20111113 There are two tools updated so that the 'Quad Faces' options to meet Thomthom's revised spec for Quad-Tool's 'quad-faces'...
      Built-in method 'group.copy' method replaced to avoid clashes with some rogue scripts that mess with built-in methods, in six of the scripts
      The Tools should now appear in the 'Plugins' Menu 'Extrude Tools' submenu and also on an 'Extrude Tools' toolbar, which you might need to activate from the View > Toolbars menu item...
      If you have an earlier installation of the tools, which had some other .rb files within the Plugins folder and some support files inside the 'TIGtools' folder then these are automatically removed as the new toolset is installed, and equivalent files are added into the new locations...
      None of the various tools' basic processes have changed in this upgrade.
      It has been done to rationalize the location of files, make the code more robust and it also anticipates possible future changes to the way plugins might work to avoid issues in the coming months... Because it deletes some old files from earlier versions you might get error messages, and it's now an Extension you'll need to restart SketchUp to register it and activate it... Restarting SketchUp should resolve these issues [you will need FULL security permissions to your Plugins folder to add the file and make the possible deletions]
      Latest update resolves some issues with 'TIGtools' folder tidy up, and require 'extensions.rb'... πŸ˜’
      Enjoy πŸ€“ PayPalButton
      To download the toolset's latest RBZ archive find its listing/download-link at the 'SCF PluginStore' page:
      http://sketchucation.com/resources/pluginstore?pln=ExtrudeTools
      then for >=v8 use the Preferences > Extensions > Install... button...
      OR you can AutoInstall it using the 'SketchUcation Plugin Store' dialog within SketchUp itself...
      http://sketchucation.com/resources/plugin-store-download...
      For earlier SketchUp versions <v8M2 add .ZIP on the end of the RBZ file's name and extract its contents into the Plugins folder manually. The top-level .rb file should go directly into the Plugins folder: the other files [rb, lingvo, png etc] must stay in the 'ExtrudeTools' subfolder, inside Plugins.
      Individual tools with the subfolder can also be disabled as desired, by adding a ! to the end of their .rb suffix... Then those won't load or make a menu/toolbar command.
      • erikBE Offline
        erikB
        Tig,
        I already installed them from the separate threads, and they work like a charm (including the toolbar.
        Thanks very much for these exellent tools. πŸ‘ ❗
        erikB
        • mitcorbM Offline
          mitcorb
          I agree with Jim, and thank you for providing this as a set. Of course, I did not see this thread until after I batch unzipped the separate ones and looked at New Posts.
            DIEGO-RODRIGUEZ
            very good contribution tig. as ever.
            greetings and thank you very much
              I agree with Jim - offering these tools as a single package only seem easier for everyone. Very nice tool set. πŸ‘
              • H Offline
                haynesc
                could some video tutorials ala chris fullmer ... explaining when its best to use which tool over the other one for us mere mortals and explain how exactly they work ... that'll be great
                  So much to do... so little time...
                  Any volunteers ? πŸ˜„
                    We should hire Chris to do a weekly video of a Featured Plugin. πŸ˜„
                    "Featured" being picked by bribery of course. πŸ˜‰
                    • Chris FullmerC Offline
                      Thats odd, I was just off playnig with another of TIG's plugins thinking about how it could use a good tutorial made for it. Perhaps it is time to dig in and start doing more script videos. They do get a lot of hits on Youtube. And I get hate mail from people saying I don't speak clearly enough. But the crickets, kids and dishes being washed in the background are big hits! πŸ˜„
                      Chris
                      All my Plugins I've written
                        Perhaps we need to start a Plugin Video Tutorial thread ?
                        We could determine which ones would be suitable for them and swap tips on how best to do it ?
                        πŸ’š πŸ€“ πŸ€“
                          ❓ 😲 Really? I've always thought you spoke very clearly in your videos. (They should hear me talking - then they'd shut up!) I have several times considered to offer to hire you to do some videos.
                            That is the cherry on the cake! 😎
                            • boofredlayB Offline
                              boofredlay
                              Chris, you need your own band playing while you do your tuts πŸ˜„
                                @arc said:
                                Here is video I created tut use EEBR.
                                Arc - it's reporting as 'blocked in your region' - at least in the UK...
                                  sunchart
                                  Thank u very much.
                                    And I get just a white square. (Norway)
                                      Pilou has updated all 4 of the FR lingvo files - they'll be included in future updates but if you want to install them straightaway then download this zip file and extract the 4 files into ../Plugins/TIGtools/ and overwrite any earlier copies...
                                      Tip: If you want the FR language for the tools' dialogs and prompts etc BUT have your locale set to another id - e.g. EN-US - then simply rename the file with that suffix and it'll be used... e.g. XxxxFR.lingvo becomes XxxxEN-US.lingvo
                                      Extrusion Tools FRlingvos.zip
                                      • ArcA Offline
                                        Arc
                                        [flash=500,405:130oyn5u]http://www.youtube.com/v/DFzteN0CvrA&hl=zh_CN&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:130oyn5u]
                                        • ArcA Offline
                                          Arc
                                          Now I upload video on youtube.
                                            Thanks, it works fine now - a quick and useful insight into just one way of using EEbyRails... πŸ˜„
                                            • 31
                                            • 32
                                            • 1 / 32
