    Does Face direction really matter?
    8 Posts 7 Posters 613 Views 7 Watching
      Jim
      What are the reasons face direction is important?
      • mitcorbM Offline
        mitcorb
        Jim:
        If you have tried/used -BTM's sculpt script, you will see quickly, upon activating the tool, that the "polarity" of the faces determines which direction the mesh is moved. Even if you use it on a TIN. This is at least in my direct experience.
        I thought that it had an effect on some renderers, however, that is still not an area I have experience in. And the reason for this is aversion to "tediosity"
          Jim,
          nuclearmoose recently had issues with front/back faces while modelling a component...
          http://forums.sketchucation.com/viewtopic.php?p=205673#p205673
          And again in this topic...
          http://forums.sketchucation.com/viewtopic.php?f=79&t=25006
          This is my understanding of how face direction matters, and Gaieus gives a very detailed and informative advice on this in the second link
            remus
            It makes a difference if you plan on rendering as well, some render engines/exporters wont give proper results if the normals are not correct.
            • Chris FullmerC Offline
              In my head this is directly related to Jim's question I promise:
              Are thie file formats that store vertex normals? Do most formats store that?
              All my Plugins I've written
                remus
                .obj can store normals, although i dont know how commonly its used.
                • honoluludesktopH Offline
                  honoluludesktop
                  Sorry for the beginners question, but can someone tell me how the first vertex in a face is determined? Is it the point of insertion? Guess the direction of the face is then related to the sequence in the array?
                  • Wo3DanW Offline
                    Wo3Dan
                    1) Front or back visible when drawing a rectangle is determined by the direction the diagonal is going.
                    Not by first and second click.
                    2)It also depends in which axes plane you are drawing.
                    Just 1) and 2) determine front and back for new rectangles not touching other rectangles. Otherwise they tend to inherite their orientations.
                    (Circles and polygons follow different rules)
                    See attached file Face_orient.skp with the diagram. Try it to see what happens when.
                    http://sketchup.google.com/3dwarehouse/details?mid=509c2a6868ab3855b2dd3120ca5e0662
