    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Display Only The Shadows [TUTORIAL]
    8 Posts 4 Posters 3.6k Views 4 Watching
    • Y Offline
      yatu
      hi there.
      i recently encountered a proplem and can't find a solution, maybe anyone here could help me? what i want to do:
      create a groundplan of a residential area, parallel projection, camera straight from above - i want to use my sketchup model to only export the shadows, which i could easily use in photoshop to make my plan (drawn in autocad) look better - i turned "display edges off", i changed the render style to "hidden lines" and within sketchup everything looks fine, i just see the shadows and everything else is displayed white - but as soon as i save the whole thing as a 2d-Picture (jpg) - i get the edges back πŸ˜• does anyone know a solution to this??
      i appreciate your help,
      thanks in advance πŸ˜„
      cheers!
        Hi Yatu,
        Please, have alook at thispost of Chris Fullmer if you can find anything helpful in there:
        http://forums.sketchucation.com/viewtopic.php?p=214056#p214056
        • Y Offline
          yatu
          thanks for your awesomely fast help guys πŸ˜„ !!!
            Not the thanks are interesting but if it helped! So did you succeed?
            πŸ˜„
              @yatu said:
              hi there.
              cheers!
              It's a known problem as Chris's post linked above - edges show up on export even when set not to display...
              Sometimes pure white edges won't work either - so make a Style that has the edges colored as near to white as you can get and still get the result you want - pure white might turn black - so try 252,252,252 etc.
              It should then export with the edges 'whited out'...
              β˜€
              • Y Offline
                yatu
                it worked like a charm!! πŸ˜„
                  OK, thanks! πŸ‘
                  • Mike LuceyM Offline
                    Mike Lucey
                    I was curious to see how things worked out for Yatu. he sent me the attached pics showing the work-flow and end image which he then was able to use for his project.
                    Mike
