    Selection by material: is there a plugin for this?
    11 Posts 4 Posters 1.3k Views 4 Watching
    • EdsonE Offline
      Edson
      i wanted to select a number of elements by their material and then erase them but could not find a plugin for this. i ran a search here and came out empty handed. would anyone know of a plugin that does that?
      http://www.mahfuz.arq.br
        You can use the built-in context-menu to select active geometry - Select a face with desired material, 'Select with same Material'
        It doesn't do Groups/Instances.
        This will do it...
        model=Sketchup.active_model
        ss=model.selection
        material=ss[0].material ### of 1st thing already selected
        ss.clear
        model.active_entities.each{|e|ss.add(e) if e.material==material}
        • EdsonE Offline
          Edson
          thanks, tig. you are always fast and tremendously helpful.
          should i place that code in the ruby console and run it or what?
            Make a plain text file called selectbysamematerial.rb in ../Plugins/
            [I know you are a Mackie so find where that is 🀣 ]
            then paste this code into it [I've added some extra bits to make it a easier to use]
            require 'sketchup.rb'
            def selectbysamematerial()
              ss=model.selection
              ss.clear
            end#def
            to use or test type/paste into the Ruby Console selectbysamematerial
            To add a menu item paste this at the end of the file
            if not file_loaded?(File.basename(__FILE__))
              UI.menu("Plugins").add_item("Select by Same Material"){selectbysamematerial()}
            file_loaded(File.basename(__FILE__))
            You can change the menu item text to "Selecione pelo Mesmo Material" if you like... πŸ˜„
            • EdsonE Offline
              Edson
              hi tig,
              thanks so much again. i followed your instructions but got the message below. i probably botched it somehow, ignoramus in ruby matters that i am. please find the script attached.
                I added such a feature for the next iterations of Selection Toys a couple of days ago - though it's not released yet.
                  @edson said:
                  hi tig,
                  Here it is corrected - you somehow had go '? ' at the start of every line of code rather than ' ' ??? ❗ ❓ πŸ˜• πŸ˜’selectbysamematerial.rb
                  • EdsonE Offline
                    Edson
                    tig,
                    it works like a charm. thanks again.
                    • Didier BurD Offline
                      Didier Bur
                      My "quick selection tool" does this also, and more πŸ˜‰
                      DB
                      • EdsonE Offline
                        Edson
                        didier,
                        to tell you the truth, my first try was with your quick selection tool – it used to be a very handy tool for me in the past – but it did not work. it never worked perfectly on my mac but after the release of 7.1 it became almost useless: the only thing i manage to select with it are components. at least for me, it will not select any materials.
                          Didier Bur
                          It seems that I have more and more updates to do, and not enough time for it now πŸŽ‰
                          DB
