    How to insert a skup model into google earth
    Scheduled Pinned Locked Moved Google Earth
    14 Posts 2 Posters 5.0k Views 2 Watching
    • N
      nightwhisper
      I have a problem importing a sketchup model into google earth. I insert the correct coordinate in sketchup but in google earth the conversion is different.
      Any ideas????
      Chiara
      • GaieusG
        Hi Chiara,
        Why aren't you rather following these easy steps instead of manually entering co-ordinates?
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36241
        • N
          nightwhisper
          Because it is a submarine model and its not possible using this tutorial (the seabed doesn't exist).
          Tks,
          Chiara
          • GaieusG
            What if you enable ocean modelling from Preferences > extensions? There IS seabed in the latest GE as well as SU.
            • N
              nightwhisper
              I need to obtain the coordinate: 44.3140, 9.1750 but in google earth are converted in 46.4000...Is there a kind of convertition?
              Chiara
              • GaieusG
                Hm. It doesn't round it for me.
                N44_3140-W9_1750.kmz
                Untitled.skp
                • N
                  nightwhisper
                  How did you do to apply the sketchup coordinate to the model?
                  • GaieusG
                    I entered the coordinates in GE and then imported the GE snapshot as per that tutorial linked above. This will import the exact same geolocation as in GE.
                    • N
                      nightwhisper
                      Good morning,
                      the cordinate are:
                      44°18’50.54” N
                      09°10’29.92” E
                      (44.314038°; 9.174979°)
                      And it's a submarine environments...
                      How can I obtain the snapshot? 😕
                      Chiara
                      • GaieusG
                        Hm. I went west, not east. So it is somewhere in the Ligurian Sea...
                        Anyway, have a look at the screenshot below (kmz file attached)
                        Your Submarine.kmz
                        • N
                          nightwhisper
                          Ok, thanks for all!
                          this is the real image...but I had to import not the image but the seabed of the point... The correct image is the following (I don't know why it is different from your)...but I can't enter into the seabed...why???
                          I'm getting crazy!!!!!!!!!!!
                          • GaieusG
                            In GE > View menu, uncheck "Water surface". This will reveal the sea bed. Also, check the Ocean layer in layers.
                            Then in SU, enable ocean modelling (as I suggested above).
                            In fact, I do not precisely know what this will do (we do not have sea here and this is all I found) but it is there for this purpose as a new feature.
                            • N
                              nightwhisper
                              Is it possible that near the coast is not possible enter into the water?
                              • GaieusG
                                I can imagine that the GE sea bed is even more inaccurate as the terrain - so I would think it is possible.
