    How to insert a skup model into google earth
    Scheduled Pinned Locked Moved Google Earth
    14 Posts 2 Posters 4.7k Views 2 Watching
      Hi Chiara,
      Why aren't you rather following these easy steps instead of manually entering co-ordinates?
      http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36241
      • N Offline
        nightwhisper
        Because it is a submarine model and its not possible using this tutorial (the seabed doesn't exist).
        Tks,
        Chiara
          What if you enable ocean modelling from Preferences > extensions? There IS seabed in the latest GE as well as SU.
          • N Offline
            nightwhisper
            I need to obtain the coordinate: 44.3140, 9.1750 but in google earth are converted in 46.4000...Is there a kind of convertition?
            Chiara
              Hm. It doesn't round it for me.
              N44_3140-W9_1750.kmz
              Untitled.skp
              • N Offline
                nightwhisper
                How did you do to apply the sketchup coordinate to the model?
                  I entered the coordinates in GE and then imported the GE snapshot as per that tutorial linked above. This will import the exact same geolocation as in GE.
                  • N Offline
                    nightwhisper
                    Good morning,
                    the cordinate are:
                    44°18’50.54” N
                    09°10’29.92” E
                    (44.314038°; 9.174979°)
                    And it's a submarine environments...
                    How can I obtain the snapshot? 😕
                    Chiara
                      Hm. I went west, not east. So it is somewhere in the Ligurian Sea...
                      Anyway, have a look at the screenshot below (kmz file attached)
                      Your Submarine.kmz
                      • N Offline
                        nightwhisper
                        Ok, thanks for all!
                        this is the real image...but I had to import not the image but the seabed of the point... The correct image is the following (I don't know why it is different from your)...but I can't enter into the seabed...why???
                        I'm getting crazy!!!!!!!!!!!
                          In GE > View menu, uncheck "Water surface". This will reveal the sea bed. Also, check the Ocean layer in layers.
                          Then in SU, enable ocean modelling (as I suggested above).
                          In fact, I do not precisely know what this will do (we do not have sea here and this is all I found) but it is there for this purpose as a new feature.
                          • N Offline
                            nightwhisper
                            Is it possible that near the coast is not possible enter into the water?
                              I can imagine that the GE sea bed is even more inaccurate as the terrain - so I would think it is possible.
