    How to insert a skup model into google earth
    Scheduled Pinned Locked Moved Google Earth
    14 Posts 2 Posters 4.4k Views 2 Watching
    • N Offline
      nightwhisper
      I have a problem importing a sketchup model into google earth. I insert the correct coordinate in sketchup but in google earth the conversion is different.
      Any ideas????
      Chiara
        Hi Chiara,
        Why aren't you rather following these easy steps instead of manually entering co-ordinates?
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36241
        • N Offline
          nightwhisper
          Because it is a submarine model and its not possible using this tutorial (the seabed doesn't exist).
          Tks,
          Chiara
            What if you enable ocean modelling from Preferences > extensions? There IS seabed in the latest GE as well as SU.
            • N Offline
              nightwhisper
              I need to obtain the coordinate: 44.3140, 9.1750 but in google earth are converted in 46.4000...Is there a kind of convertition?
              Chiara
                Hm. It doesn't round it for me.
                N44_3140-W9_1750.kmz
                Untitled.skp
                • N Offline
                  nightwhisper
                  How did you do to apply the sketchup coordinate to the model?
                    I entered the coordinates in GE and then imported the GE snapshot as per that tutorial linked above. This will import the exact same geolocation as in GE.
                    • N Offline
                      nightwhisper
                      Good morning,
                      the cordinate are:
                      44Β°18’50.54” N
                      09Β°10’29.92” E
                      (44.314038Β°; 9.174979Β°)
                      And it's a submarine environments...
                      How can I obtain the snapshot? πŸ˜•
                      Chiara
                        Hm. I went west, not east. So it is somewhere in the Ligurian Sea...
                        Anyway, have a look at the screenshot below (kmz file attached)
                        Your Submarine.kmz
                        • N Offline
                          nightwhisper
                          Ok, thanks for all!
                          this is the real image...but I had to import not the image but the seabed of the point... The correct image is the following (I don't know why it is different from your)...but I can't enter into the seabed...why???
                          I'm getting crazy!!!!!!!!!!!
                            In GE > View menu, uncheck "Water surface". This will reveal the sea bed. Also, check the Ocean layer in layers.
                            Then in SU, enable ocean modelling (as I suggested above).
                            In fact, I do not precisely know what this will do (we do not have sea here and this is all I found) but it is there for this purpose as a new feature.
                            • N Offline
                              nightwhisper
                              Is it possible that near the coast is not possible enter into the water?
                                I can imagine that the GE sea bed is even more inaccurate as the terrain - so I would think it is possible.
