    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 15.8k Views 16 Watching
    • olisheaO
      olishea
      here is another one:
      could do with some more contrast though....
      http://i654.photobucket.com/albums/uu269/olishea/4_final-1.jpg
      cheers
      oli
      • olisheaO
        olishea
        different PP:
        http://i654.photobucket.com/albums/uu269/olishea/4_final-2.jpg
        oli
        • olisheaO
          olishea
          another angle. man im tired!
          tried some dirt maps/grunge maps in this one.
          comments appreciated.
          http://i654.photobucket.com/albums/uu269/olishea/27_final-1.jpg
          oli
          • RichardR
            Richard
            Mate looks like you need to play with the curves editor in PS! It can really make an image pop by adding contrast without loosing colour depth! Drag top quarter of diagonal left and bottom quarter right is a quick and dirty method to dress result!
            BUILTBRAND.COM.AU
            • olisheaO
              olishea
              hmmm. i always use curves. maybe not enough. are you saying it needs more contrast? I highly value your opinion.
              here is another:
              http://i654.photobucket.com/albums/uu269/olishea/6_final-4.jpg
              oli
              • C
                cadmunkey
                Oli, I think the contrast of the raw render is fine, it is probably the poor contrast of the entourage that is confusing things.
                • W
                  watkins
                  Dear Oli,
                  Perhaps some barriers at the curb side to stop children running down the slopes and straight on to the road? It would also discourage skateboard users too. Are the gambions less attractive to graffiti artists? Have you thought about external lighting to discourage vandalism?
                  Regards,
                  Bob
                  • W
                    watkins
                    Dear Oli,
                    I forgot to ask about energy conservation. Are these houses being designed for minimum heat loss? I ask because electricity and gas bills are a significant fraction of a low wage earner's income. Could hot water be supplied from a metered central source (per building block)? If so, then solar panels would work.
                    Regards,
                    Bob
                    • olisheaO
                      olishea
                      of course they are, this is the 21 century. many of the houses are zero-emission level 6 eco-houses and the rest are very, very efficient. It's a landmark eco-scheme.
                      can you not see them on some of the roofs?
                      They cannot skateboard on grass and gravel. The pavement is the only place they could possibly find useful...so let the ruin their boards on the curb. We are more concerned about violent assault and robberies than people skateboarding to be honest....it would actually be a blessing if people were skateboarding here...makes a change to smashing up phones boxes. 😄
                      oli
                      • W
                        watkins
                        Dear oli,
                        Yes, I do realise that this is the 21st century, but you mentioned that they are council houses, and council houses (in the past, and in many case) have been designed and built to bottom dollar. Small and pokey, poor heat and sound insulation, and to a design that just begs for the wrecking ball. There are many examples of council housing estates that bear witness to this philosophy.
                        I thought the shapes on the roof were skylights. Are you using the roof space as living space?
                        Regards,
                        Bob
                        • W
                          watkins
                          Dear Oli,
                          Sorry, should have looked more closely at the roofs. As those large dormer windows? Are you using solar hot water panels or PV panels. It looks like you have PV panels on one roof.
                          Just interested, that's all.
                          Regards,
                          Bob
                          • olisheaO
                            olishea
                            PV and yes roof space is occupied in most cases. This is just part of a huge housing scheme, the level 6 houses are 'example' homes, a demonstration of what can be done and a move forward. it would be ludicrous for every home to be level 6. I understand your observations of past housing schemes but these are built to completely different standards and regulations. good design doesn't/shouldn't cost any more.
                            oli
                            • W
                              watkins
                              Oli wrote:
                              "good design doesn't/shouldn't cost any more"
                              Amen to that!
                              • C
                                cadmunkey
                                The section looks great Oli, hope your bosses are proud of it! The scheme will look great when its built.
                                • D
                                  dylan
                                  You have the grass looking well now oli.
                                  Are you using a mask with an image of grass?
                                  http://dmdarchitecture.co.uk/
                                  • olisheaO
                                    olishea
                                    perspective section:
                                    (oops i mean perspective elevation!)
                                    http://i654.photobucket.com/albums/uu269/olishea/section_3-1.jpg
                                    comments welcome as always
                                    oli
                                    • olisheaO
                                      olishea
                                      In the above elevation its just raw render, but the other images are made using the grass tutorial on the twilight forum. so yeah an image underneath the masked render...then use the dune grass brush (in photoshop...make sure you lower the 'opacity jitter' aka 'foreground/background jitter' or you get transparent grass) to give the blades of grass. takes a while to get it right but worth it.
                                      thanks for the comments. cadmunkey: i hope my bosses are proud too!
                                      oli
                                      • olisheaO
                                        olishea
                                        Finally, all together on drawing sheets!
                                        http://i654.photobucket.com/albums/uu269/olishea/1_revA_small.jpg
                                        http://i654.photobucket.com/albums/uu269/olishea/2_revA_small.jpg
                                        oli
                                          21D
                                          these looks amazing, did you do the PLAN in sketchup also, if not, which app did you use for that??
                                          "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                                          Le Corbusier
                                            Great final product Oli 👍
                                            Congrats on the tutorial on SUArtists, very informative and detailed.
                                            • 3 / 4
