    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 15.8k Views 16 Watching
    • olisheaO
      olishea
      another angle. man im tired!
      tried some dirt maps/grunge maps in this one.
      comments appreciated.
      http://i654.photobucket.com/albums/uu269/olishea/27_final-1.jpg
      oli
      • RichardR
        Richard
        Mate looks like you need to play with the curves editor in PS! It can really make an image pop by adding contrast without loosing colour depth! Drag top quarter of diagonal left and bottom quarter right is a quick and dirty method to dress result!
        BUILTBRAND.COM.AU
        • olisheaO
          olishea
          hmmm. i always use curves. maybe not enough. are you saying it needs more contrast? I highly value your opinion.
          here is another:
          http://i654.photobucket.com/albums/uu269/olishea/6_final-4.jpg
          oli
          • C
            cadmunkey
            Oli, I think the contrast of the raw render is fine, it is probably the poor contrast of the entourage that is confusing things.
            • W
              watkins
              Dear Oli,
              Perhaps some barriers at the curb side to stop children running down the slopes and straight on to the road? It would also discourage skateboard users too. Are the gambions less attractive to graffiti artists? Have you thought about external lighting to discourage vandalism?
              Regards,
              Bob
              • W
                watkins
                Dear Oli,
                I forgot to ask about energy conservation. Are these houses being designed for minimum heat loss? I ask because electricity and gas bills are a significant fraction of a low wage earner's income. Could hot water be supplied from a metered central source (per building block)? If so, then solar panels would work.
                Regards,
                Bob
                • olisheaO
                  olishea
                  of course they are, this is the 21 century. many of the houses are zero-emission level 6 eco-houses and the rest are very, very efficient. It's a landmark eco-scheme.
                  can you not see them on some of the roofs?
                  They cannot skateboard on grass and gravel. The pavement is the only place they could possibly find useful...so let the ruin their boards on the curb. We are more concerned about violent assault and robberies than people skateboarding to be honest....it would actually be a blessing if people were skateboarding here...makes a change to smashing up phones boxes. πŸ˜„
                  oli
                  • W
                    watkins
                    Dear oli,
                    Yes, I do realise that this is the 21st century, but you mentioned that they are council houses, and council houses (in the past, and in many case) have been designed and built to bottom dollar. Small and pokey, poor heat and sound insulation, and to a design that just begs for the wrecking ball. There are many examples of council housing estates that bear witness to this philosophy.
                    I thought the shapes on the roof were skylights. Are you using the roof space as living space?
                    Regards,
                    Bob
                    • W
                      watkins
                      Dear Oli,
                      Sorry, should have looked more closely at the roofs. As those large dormer windows? Are you using solar hot water panels or PV panels. It looks like you have PV panels on one roof.
                      Just interested, that's all.
                      Regards,
                      Bob
                      • olisheaO
                        olishea
                        PV and yes roof space is occupied in most cases. This is just part of a huge housing scheme, the level 6 houses are 'example' homes, a demonstration of what can be done and a move forward. it would be ludicrous for every home to be level 6. I understand your observations of past housing schemes but these are built to completely different standards and regulations. good design doesn't/shouldn't cost any more.
                        oli
                        • W
                          watkins
                          Oli wrote:
                          "good design doesn't/shouldn't cost any more"
                          Amen to that!
                          • C
                            cadmunkey
                            The section looks great Oli, hope your bosses are proud of it! The scheme will look great when its built.
                              dylan
                              You have the grass looking well now oli.
                              Are you using a mask with an image of grass?
                              http://dmdarchitecture.co.uk/
                              • olisheaO
                                olishea
                                perspective section:
                                (oops i mean perspective elevation!)
                                http://i654.photobucket.com/albums/uu269/olishea/section_3-1.jpg
                                comments welcome as always
                                oli
                                • olisheaO
                                  olishea
                                  In the above elevation its just raw render, but the other images are made using the grass tutorial on the twilight forum. so yeah an image underneath the masked render...then use the dune grass brush (in photoshop...make sure you lower the 'opacity jitter' aka 'foreground/background jitter' or you get transparent grass) to give the blades of grass. takes a while to get it right but worth it.
                                  thanks for the comments. cadmunkey: i hope my bosses are proud too!
                                  oli
                                  • olisheaO
                                    olishea
                                    Finally, all together on drawing sheets!
                                    http://i654.photobucket.com/albums/uu269/olishea/1_revA_small.jpg
                                    http://i654.photobucket.com/albums/uu269/olishea/2_revA_small.jpg
                                    oli
                                      21D
                                      these looks amazing, did you do the PLAN in sketchup also, if not, which app did you use for that??
                                      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                                      Le Corbusier
                                        Great final product Oli πŸ‘
                                        Congrats on the tutorial on SUArtists, very informative and detailed.
                                        • olisheaO
                                          olishea
                                          21D: the site plan is made with autocad. All drawings were done in autocad and imported into SU.
                                          Thanks for the nice comments, i'm happy how everything came out. And James.....I have to admit it's not quite the quasi-clay style...its just straight SU output with a gradient and vignette (didn't have to time to render any more). So let's call it the demi-quasi-clay style lol πŸ‘
                                          In isolation I do not think the images are so spectacular but as a narrative they work very nicely IMO.
                                          Thank you everyone for all your input. πŸ˜„
                                          oli
                                          • michaliszissiouM
                                            michaliszissiou
                                            Layouts are terrific Oli. I must say that I had my doubts about how a photo sky works with CG. As with the cut outs too. But it looks great now. Just this road texture still looks out of scale but it 'works'. πŸ‘ πŸ‘ πŸ‘
                                            • 3 / 4
