    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 13.8k Views 16 Watching
    • olisheaO Offline
      olishea
      here is another angle. image is not as good quality as the others but it will have to do!
      http://i654.photobucket.com/albums/uu269/olishea/3_final_revA-1.jpg
      oli
      • olisheaO Offline
        olishea
        here is another one:
        could do with some more contrast though....
        http://i654.photobucket.com/albums/uu269/olishea/4_final-1.jpg
        cheers
        oli
        • olisheaO Offline
          olishea
          different PP:
          http://i654.photobucket.com/albums/uu269/olishea/4_final-2.jpg
          oli
          • olisheaO Offline
            olishea
            another angle. man im tired!
            tried some dirt maps/grunge maps in this one.
            comments appreciated.
            http://i654.photobucket.com/albums/uu269/olishea/27_final-1.jpg
            oli
            • RichardR Offline
              Richard
              Mate looks like you need to play with the curves editor in PS! It can really make an image pop by adding contrast without loosing colour depth! Drag top quarter of diagonal left and bottom quarter right is a quick and dirty method to dress result!
              [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
              • olisheaO Offline
                olishea
                hmmm. i always use curves. maybe not enough. are you saying it needs more contrast? I highly value your opinion.
                here is another:
                http://i654.photobucket.com/albums/uu269/olishea/6_final-4.jpg
                oli
                  cadmunkey
                  Oli, I think the contrast of the raw render is fine, it is probably the poor contrast of the entourage that is confusing things.
                  • W Offline
                    watkins
                    Dear Oli,
                    Perhaps some barriers at the curb side to stop children running down the slopes and straight on to the road? It would also discourage skateboard users too. Are the gambions less attractive to graffiti artists? Have you thought about external lighting to discourage vandalism?
                    Regards,
                    Bob
                    • W Offline
                      watkins
                      Dear Oli,
                      I forgot to ask about energy conservation. Are these houses being designed for minimum heat loss? I ask because electricity and gas bills are a significant fraction of a low wage earner's income. Could hot water be supplied from a metered central source (per building block)? If so, then solar panels would work.
                      Regards,
                      Bob
                      • olisheaO Offline
                        olishea
                        of course they are, this is the 21 century. many of the houses are zero-emission level 6 eco-houses and the rest are very, very efficient. It's a landmark eco-scheme.
                        can you not see them on some of the roofs?
                        They cannot skateboard on grass and gravel. The pavement is the only place they could possibly find useful...so let the ruin their boards on the curb. We are more concerned about violent assault and robberies than people skateboarding to be honest....it would actually be a blessing if people were skateboarding here...makes a change to smashing up phones boxes. 😄
                        oli
                        • W Offline
                          watkins
                          Dear oli,
                          Yes, I do realise that this is the 21st century, but you mentioned that they are council houses, and council houses (in the past, and in many case) have been designed and built to bottom dollar. Small and pokey, poor heat and sound insulation, and to a design that just begs for the wrecking ball. There are many examples of council housing estates that bear witness to this philosophy.
                          I thought the shapes on the roof were skylights. Are you using the roof space as living space?
                          Regards,
                          Bob
                          • W Offline
                            watkins
                            Dear Oli,
                            Sorry, should have looked more closely at the roofs. As those large dormer windows? Are you using solar hot water panels or PV panels. It looks like you have PV panels on one roof.
                            Just interested, that's all.
                            Regards,
                            Bob
                            • olisheaO Offline
                              olishea
                              PV and yes roof space is occupied in most cases. This is just part of a huge housing scheme, the level 6 houses are 'example' homes, a demonstration of what can be done and a move forward. it would be ludicrous for every home to be level 6. I understand your observations of past housing schemes but these are built to completely different standards and regulations. good design doesn't/shouldn't cost any more.
                              oli
                              • W Offline
                                watkins
                                Oli wrote:
                                "good design doesn't/shouldn't cost any more"
                                Amen to that!
                                  cadmunkey
                                  The section looks great Oli, hope your bosses are proud of it! The scheme will look great when its built.
                                    dylan
                                    You have the grass looking well now oli.
                                    Are you using a mask with an image of grass?
                                    http://dmdarchitecture.co.uk/
                                    • olisheaO Offline
                                      olishea
                                      perspective section:
                                      (oops i mean perspective elevation!)
                                      http://i654.photobucket.com/albums/uu269/olishea/section_3-1.jpg
                                      comments welcome as always
                                      oli
                                      • olisheaO Offline
                                        olishea
                                        In the above elevation its just raw render, but the other images are made using the grass tutorial on the twilight forum. so yeah an image underneath the masked render...then use the dune grass brush (in photoshop...make sure you lower the 'opacity jitter' aka 'foreground/background jitter' or you get transparent grass) to give the blades of grass. takes a while to get it right but worth it.
                                        thanks for the comments. cadmunkey: i hope my bosses are proud too!
                                        oli
                                        • olisheaO Offline
                                          olishea
                                          Finally, all together on drawing sheets!
                                          http://i654.photobucket.com/albums/uu269/olishea/1_revA_small.jpg
                                          http://i654.photobucket.com/albums/uu269/olishea/2_revA_small.jpg
                                          oli
                                          • 2 Offline
                                            21D
                                            these looks amazing, did you do the PLAN in sketchup also, if not, which app did you use for that??
                                            "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                                            Le Corbusier
                                            • 3 / 4
