    [Plugin] Edge Tools
    209 Posts 73 Posters 265.5k Views 73 Watching
      Version 2.0.2
      • Fixed minor namespace reference issue.
        dedmin
        πŸ‘ πŸ‘ πŸ‘ πŸ‘
          rv1974
          Thank you for all february 05 goodies.
            @dedmin said:
            [attachment=0:375j5dqr]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:375j5dqr]
            Thanks for reporting that. I was a bit quick to release the last fix so I forgot to test it before shipping. 😳
              dedmin
              @thomthom said:
              @dedmin said:
              [attachment=0:1l1j5985]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1l1j5985]
              That is the minimum we can do to respect and help plugin's writers! β˜€
              • ArcA Offline
                Arc
                Perfect Thomthom, you're the best.
                  Ben Ritter
                  Thank you again for being willing to share your work.
                    bentleykfrog
                    @thomthom said:
                    @bentleykfrog said:
                    Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
                    thanks thomthom
                    Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. πŸ‘
                    I'm in love with close gaps! It saves me so much time repairing 3d warehouse models.
                    Ohh and I just thought of something else for divide faces. It would be cool if it could snap to previously entered distances, like the line or move tool does.
                    thanks again for your hard work thomthom
                      Yea - that's a good idea. There's a few things I'd like to add to it.
                      • demD Offline
                        dem
                        Line disappears, when I try to snap it with angle matching on another side. 😞
                        http://dem.inf.ua/skp/oops.png
                          Are you keeping the cursor over the face?
                          (I know it's something that could use some improvement.)
                          • demD Offline
                            dem
                            Yes. And I notice vertical snap, when moving cursor down.
                            http://dem.inf.ua/skp/snap.png
                              That is something I can not control - it's the SketchUp inference engine.
                              • K Offline
                                kreartur
                                Hi Thomas
                                I'd love to use your cool tool but after installing the files I always get the following window saying:
                                uninitialized constant TT::LibFehler beim Laden der Datei tt_edgetools.rb
                                what can I do to run your program?
                                Thank you
                                  @kreartur said:
                                  Hi Thomas
                                  Thank you
                                  Go to the download page [post#1] and use the link to the required 'Library' [TT_Lib2] and install in the Plugins folder as instructedCapture.PNG
                                    cobb89
                                    is close gaps same as the commercial plugin CloseOpens available on smustard??...I haven't used CloseOpens.. πŸ˜’
                                      ahnvtk
                                      These are really useful, thanks!
                                      It wasn't so obvious how to enter a distance threshold (or that you needed to) in the "Value Control Box" (measurements toolbar) for the "close edge gaps" tool. After you select the tool it seems you can't select the measurement toolbar; apparently you're just supposed to type. If the toolbar can be selected that will be a bit more intuitive.
                                      However I'm not figuring out how to use the "make vertices colinear" at all; where is that demonstrated (or where could it be)?
                                        ahnvtk
                                        Oh, I figured that last out; re-read the post really carefully πŸ˜„ a video shows best however.
                                          I don't know what CloseOpens is... πŸ˜•
                                            That's not something I can control. It's how SketchUp works. All tools that use the VCB acts like that.
                                            • 6
                                            • 10
                                            • 11
                                            • 4 / 11
