    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
      dedmin
        Version 2.0.2
        • Fixed minor namespace reference issue.
          dedmin
          πŸ‘ πŸ‘ πŸ‘ πŸ‘
            rv1974
            Thank you for all february 05 goodies.
              @dedmin said:
              [attachment=0:375j5dqr]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:375j5dqr]
              Thanks for reporting that. I was a bit quick to release the last fix so I forgot to test it before shipping. 😳
                dedmin
                @thomthom said:
                @dedmin said:
                [attachment=0:1l1j5985]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1l1j5985]
                That is the minimum we can do to respect and help plugin's writers! β˜€
                • ArcA
                  Arc
                  Perfect Thomthom, you're the best.
                  • B
                    Ben Ritter
                    Thank you again for being willing to share your work.
                    • B
                      bentleykfrog
                      @thomthom said:
                      @bentleykfrog said:
                      Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
                      thanks thomthom
                      Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. πŸ‘
                      I'm in love with close gaps! It saves me so much time repairing 3d warehouse models.
                      Ohh and I just thought of something else for divide faces. It would be cool if it could snap to previously entered distances, like the line or move tool does.
                      thanks again for your hard work thomthom
                        Yea - that's a good idea. There's a few things I'd like to add to it.
                        • demD
                          dem
                          Line disappears, when I try to snap it with angle matching on another side. 😞
                          http://dem.inf.ua/skp/oops.png
                            Are you keeping the cursor over the face?
                            (I know it's something that could use some improvement.)
                            • demD
                              dem
                              Yes. And I notice vertical snap, when moving cursor down.
                              http://dem.inf.ua/skp/snap.png
                                That is something I can not control - it's the SketchUp inference engine.
                                • K
                                  kreartur
                                  Hi Thomas
                                  I'd love to use your cool tool but after installing the files I always get the following window saying:
                                  uninitialized constant TT::LibFehler beim Laden der Datei tt_edgetools.rb
                                  what can I do to run your program?
                                  Thank you
                                    @kreartur said:
                                    Hi Thomas
                                    Thank you
                                    Go to the download page [post#1] and use the link to the required 'Library' [TT_Lib2] and install in the Plugins folder as instructedCapture.PNG
                                    • C
                                      cobb89
                                      is close gaps same as the commercial plugin CloseOpens available on smustard??...I haven't used CloseOpens.. πŸ˜’
                                        ahnvtk
                                        These are really useful, thanks!
                                        It wasn't so obvious how to enter a distance threshold (or that you needed to) in the "Value Control Box" (measurements toolbar) for the "close edge gaps" tool. After you select the tool it seems you can't select the measurement toolbar; apparently you're just supposed to type. If the toolbar can be selected that will be a bit more intuitive.
                                        However I'm not figuring out how to use the "make vertices colinear" at all; where is that demonstrated (or where could it be)?
                                          ahnvtk
                                          Oh, I figured that last out; re-read the post really carefully πŸ˜„ a video shows best however.
                                            I don't know what CloseOpens is... πŸ˜•
                                            • 11
                                            • 4 / 11
