    Invisible sketchup model when VRAY rendering
    renderpluginsextensions
    4 Posts 2 Posters 3.3k Views 2 Watching
    • S
      sinanp
      Having some issues trying to render a sketchup model using VRAY. All that appears in the render is the landscape surface I made using contours. The rest of the model is invisible, I've tried applying VRAY material to groups and all the lines/surfaces within the group (not sure if I need to do the latter, is applying materials to groups alone enough?) but still to no avail?
      • thomthomT
        what version of V-Ray for Sketchup do you use?
        What does it say in the About section?
        • S
          sinanp
          Not quite sure what happened but the install must have been corrupted/faulty reinstalled VRAY and finally getting some model outputs! thanks very much
          • thomthomT
            Or ... it could be the disappearing group bug. Which will correct itself if you reload the file...
