    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] Select_Only
    6 Posts 5 Posters 8.5k Views 5 Watching
      In response to a request here's a quick and simple context_menu tool to limit a selection to only Edges or Faces.
      For example, you select some things and then right-click, and in the context_menu choose <<< Select ONLY Edges - this will remove everything else from the selection, except the Edges... similarly use the other option for Faces etc... The options only appear if there is at least one of that type of entity [Edge or Face] in the original selection set...Put this in Plugins folder and restart SUp PayPalButton
        My Selection Toys also does that.
        • Didier BurD Offline
          Didier Bur
          And my "quick selection" tool as well ๐Ÿ˜›
          DB
          • plot-parisP Offline
            plot-paris
            ๐Ÿ˜„ we are not short of choices then...
            • 1 Offline
              18870314
              why I can't download
                This thread is SIX years old. ๐Ÿ˜ฎ
                The RB file which is linked in the first post would probably work if it were downloaded then manually installed into your SketchUp Plugins folder.
                If you have an Ad-Blocker set for SCF's pages, it is against the ToS you agreed to, and downloading/images etc may then get blocked - disable it foe SCF - the revenue from its discreet relevant banner-ads helps to pay for this site's very existence !
                However, there are now many superior tools available - e.g. thomthom's Selection-Toys [his tools need his Lib too].
                I suggest you search in the SketchUcation PluginStore...
                Or the EW for suitable extensions...
                The newer tools' RBZs are readily installed using the native-installer, so no need to even mess on finding your Plugins folder!
