    Behavior: shadows_face_sun
    9 Posts 4 Posters 1.1k Views 4 Watching
      tpoz
      Hello everyone!
      I have a question about behavior. I am trying to draw a 2d component and have it follow the sun using .shadows_face_sun. I can't seem to make it follow the sun.
      Here is some code:
      shruw = 15
      shruh = 20
      shr0 = [shruw/2,0,0]
      shr1 = [-shruw/2,0,0]
      shr2 = [-shruw/2,0,shruh]
      shr3 = [shruw/2,0,shruh]
      point = Geom;;Point3d 0,0,0
      transform = Geom;;Transformation.new point
      trees = model.definitions.add("MyShrub")
      shrubbie = trees.entities.add_face(shr0, shr1, shr2, shr3)
      shrubbie.material = "ForestGreen"
      shrubbie.back_material = "ForestGreen"
      model.active_entities.add_instance(trees, transform)
      model.active_view.zoom_extents
      trees.behavior.shadows_face_sun = true
      I've tried a few other things like
      behavior = model.definitions[0].behavior
       beehive = behavior.always_face_camera = true
      I think I am using the definition wrong or something when i use behavior.
      Any help is greatly appreciated!
      Thanks,
      Laura
        Have you checked the definition you get when you use model.definitions["MyShrub"] ?
        In any case, just use the name if you know it.
        behavior = model.definitions["MyShrub"].behavior
          RickW
          You are aware that shadows_face_sun does not affect the representation of the component instance itself, but only its shadows, right? In other words, the instance will not rotate to follow the sun; only the shadows will change when the sun changes while the instance remains static.
          RickW
          www.smustard.com
            Think there was a DC that followed the sun...
              DCs got it built in:
              http://sketchup.google.com/support/bin/answer.py?hl=en&answer=115749
              SUNANGLE()
              not sure if it auto updates though...
                There are several plugins that get the sun's position [e.g. Jim's suntool.rb].
                You need to find it and use it to determine you component's rotation in 3D ?
                Could be a DC [sunangle_function.skp etc on 3DWarehouse] or a Component with attached an observer that finds the sun an rotates it to suit - triggered by some event - like a change of the view ?
                  RickW
                  @tig said:
                  ...or a Component with attached an observer that finds the sun an rotates it to suit - triggered by some event - like a change of the view ?
                  or a ShadowInfoObserver 😉
                  RickW
                  www.smustard.com
                    I was talking out the top of my head again... 😉
                      tpoz
                      Hey,
                      It turns out that thomthom's first suggestion was the one!
                      I thought I had tried that, thanks for the posts everyone!
                      Laura
