    Drawing Dados and Rabbits
    7 Posts 4 Posters 1.8k Views 4 Watching
    • G
      grc
      Looking for a faster way to draw dados and rabbits.
      • M
        mac1
        Need to be more specific. How are you drawing them now and what is your specific usage. Initial thought is to use rectangle tool to draw 2d of dado or rabbit and PP to desired depth. If you want them on curved edge them approach is differnt. A poorly defined question like this usually take too long time / work to answer since it turns into a 64 question session. 😄
        • G
          grc
          I'll try better with my questions. Specific usage: in wooden cabinet parts of a drawing. A dado for example, I draw the 2 lines on the face of the board 3/4" apart, then draw the lines representing the cut outs on either side of the board, then delete or erase the middle section and add the 2 lines in the bottom of the dado. This seems to work sometimes, but other times the face or skin doesn't fill in and it's time consuming. I thought there might be someone working on a plug-in for this. I'd trird the push/pull method, seems to be working. Any other ideals would be appreciated.
          • TIGT
            PushPull and FollowMe can help: there is also an inexpensive ProfileMaker script available at the Smustard site...
              Does hare can be considered as a rabbit?
              So you have an example here 😉
              • TIGT
                Pilou - naught, naughty... 😆
                'Rabbit' is an archaic English spelling of 'Rebate' or 'Rabbet'
                Such as...
                1. A deep notch formed in or near one edge of a board, framing timber, etc., so that something else can be fitted into it or so that a door or the like can be closed against it.
                2. A broad groove let into the surface of a board or the like; dado.
                *Pilou - rien, méchant, méchant... 😆
                'Rabbit' est un orthographe archaïque anglais de 'Rebate' ou 'Rabbet' == «Rainure» [ici 'Rebate' ne signifie pas à rabaiser ou faire dégrèvement: ici 'Rebate' est aussi un également de «Rainure» en anglais] tels que ..
                1. Une entaille profonde formés dans ou près d'un bord d'un conseil, charpente, etc., Pour que quelque chose d'autre peut être monté dedans, ou que d'une porte ou similaires peut être fermé à son encontre
                  2 Une large rainure laisser entrer dans la surface d'un bord ou de produits similaires; dado.
                  «Rabbit» n'est pas a le lapin ! 😉*
                  Sorry for missunderstanding 😄
                  I was so literal 😄
