    3D fillet
    12 Posts 6 Posters 4.2k Views 6 Watching
      jukkoo
      Is there a plugin that does this? like a 3d fillet, maybe even if 3 planes are intersecting
      http://img69.imageshack.us/img69/7647/questionb.jpg
        Like Round Corner by Fredo?
        http://forums.sketchucation.com/viewtopic.php?f=323&t=20485
        (watch the video he attached)
          jukkoo
          ok, fredo is officialy my idol. After fredo scale now I found this!! Thanks gaieus
          • Chris FullmerC Offline
            Hehehe, just wait til you find Tools on Surface, Joint Push/Pull, Ghost Comp, and everything else Fredo has written....!
            Chris
            All my Plugins I've written
              timreger
              I am trying to use RoundCorner to fillet into a 3 way corner.
              It works in block 1 but not when a wedge is in blocks 2 & 3.
              I am trying to do a bracket similar to block 3.
              Any help appreciated.
              Tim
              whynot.skp
              • cottyC Offline
                cotty
                like this?
                my SketchUp gallery
                • gillesG Offline
                  gilles
                  Yes, but if you need this RoundCorner does not work.
                    timreger
                    Hey cotty
                    That is exactly what I did but the result was quite different as in my model.
                    So what did I do wrong - different settings maybe?
                    Tim
                      timreger
                      Nope, not exactly!
                      Followed your steps and it worked.
                      Redrew it my way and it didn't.
                      The difference - I drew the web differently.
                      You drew a rectangular prism then cut it in half diagonally.
                      I drew the triangle shape of the rib with single lines and then pushed it back.
                      Go figure! Why would it be different?
                      BTW - like the online video recording. I can use that with my students.
                      • cottyC Offline
                        cotty
                        I think this is the reason for your problem: with your creation of the triangle, some faces gets reversed and there is an inner face...
                        my SketchUp gallery
                          timreger
                          What happens when different fillet radii meet? In attached drawing:
                          Block 1 - same radius (5) all happy.
                          Block 2 - 15 radius
                          Block 3 - 5 radius
                          Block 4 - 5 radius first and then 15 - not happy.
                          Block 5 - 15 radius first and then 5 - not happy.
                          All done with RoundCorner.
                          Can it be made to work?
                          whynot2.skp
                          • cottyC Offline
                            cotty
                            If you repair one corner by hand, you will see why the plugin has problems to make it...
                            my SketchUp gallery
