    3D fillet
    12 Posts 6 Posters 4.3k Views 6 Watching
      jukkoo
      ok, fredo is officialy my idol. After fredo scale now I found this!! Thanks gaieus
      • Chris FullmerC
        Hehehe, just wait til you find Tools on Surface, Joint Push/Pull, Ghost Comp, and everything else Fredo has written....!
        • T
          timreger
          I am trying to use RoundCorner to fillet into a 3 way corner.
          It works in block 1 but not when a wedge is in blocks 2 & 3.
          I am trying to do a bracket similar to block 3.
          Any help appreciated.
          Tim
          whynot.skp
          • cottyC
            cotty
            like this?
            my SketchUp gallery
            • gillesG
              gilles
              Yes, but if you need this RoundCorner does not work.
              • T
                timreger
                Hey cotty
                That is exactly what I did but the result was quite different as in my model.
                So what did I do wrong - different settings maybe?
                Tim
                • T
                  timreger
                  Nope, not exactly!
                  Followed your steps and it worked.
                  Redrew it my way and it didn't.
                  The difference - I drew the web differently.
                  You drew a rectangular prism then cut it in half diagonally.
                  I drew the triangle shape of the rib with single lines and then pushed it back.
                  Go figure! Why would it be different?
                  BTW - like the online video recording. I can use that with my students.
                  • cottyC
                    cotty
                    I think this is the reason for your problem: with your creation of the triangle, some faces gets reversed and there is an inner face...
                    my SketchUp gallery
                    • T
                      timreger
                      What happens when different fillet radii meet? In attached drawing:
                      Block 1 - same radius (5) all happy.
                      Block 2 - 15 radius
                      Block 3 - 5 radius
                      Block 4 - 5 radius first and then 15 - not happy.
                      Block 5 - 15 radius first and then 5 - not happy.
                      All done with RoundCorner.
                      Can it be made to work?
                      whynot2.skp
                      • cottyC
                        cotty
                        If you repair one corner by hand, you will see why the plugin has problems to make it...
                        my SketchUp gallery
