    3D fillet
    12 Posts 6 Posters 4.3k Views 6 Watching
    • GaieusG
      Like Round Corner by Fredo?
      http://forums.sketchucation.com/viewtopic.php?f=323&t=20485
      (watch the video he attached)
        jukkoo
        ok, fredo is officialy my idol. After fredo scale now I found this!! Thanks gaieus
        • Chris FullmerC
          Hehehe, just wait til you find Tools on Surface, Joint Push/Pull, Ghost Comp, and everything else Fredo has written....!
          • T
            timreger
            I am trying to use RoundCorner to fillet into a 3 way corner.
            It works in block 1 but not when a wedge is in blocks 2 & 3.
            I am trying to do a bracket similar to block 3.
            Any help appreciated.
            Tim
            whynot.skp
            • cottyC
              cotty
              like this?
              my SketchUp gallery
              • gillesG
                gilles
                Yes, but if you need this RoundCorner does not work.
                • T
                  timreger
                  Hey cotty
                  That is exactly what I did but the result was quite different as in my model.
                  So what did I do wrong - different settings maybe?
                  Tim
                  • T
                    timreger
                    Nope, not exactly!
                    Followed your steps and it worked.
                    Redrew it my way and it didn't.
                    The difference - I drew the web differently.
                    You drew a rectangular prism then cut it in half diagonally.
                    I drew the triangle shape of the rib with single lines and then pushed it back.
                    Go figure! Why would it be different?
                    BTW - like the online video recording. I can use that with my students.
                    • cottyC
                      cotty
                      I think this is the reason for your problem: with your creation of the triangle, some faces gets reversed and there is an inner face...
                      my SketchUp gallery
                      • T
                        timreger
                        What happens when different fillet radii meet? In attached drawing:
                        Block 1 - same radius (5) all happy.
                        Block 2 - 15 radius
                        Block 3 - 5 radius
                        Block 4 - 5 radius first and then 15 - not happy.
                        Block 5 - 15 radius first and then 5 - not happy.
                        All done with RoundCorner.
                        Can it be made to work?
                        whynot2.skp
                        • cottyC
                          cotty
                          If you repair one corner by hand, you will see why the plugin has problems to make it...
                          my SketchUp gallery
