    Blender 2.5 Alpha 0
    extensions
    28 Posts 9 Posters 5.6k Views 9 Watching
    • R
      remus
      http://www.blender.org/download/get-25-alpha/
      Ive been playing around with some of the early builds and its very good. A lot more intuitive than previous incarnations.
      • thomthomT
        How much? I've installed Blender on a number of occations without being able to do anything other than place a square. Admittedly, I didn't RTFM, but I just got really discouraged that I couldn't get any further without. Even in 3DSMax I got a long way playing around before I needed to read the manual.
        • R
          remus
          To be honest, ive only just scratched the surface of what blenders capable of (a little bit of modelling and UVmapping) but it was fun while i was doing it!
          For me the main improvement is that i now quite enjoy poking around and playing about with it, whereas before it always felt like a chore to try and use it.
          • thomthomT
            I might just download and try it. What is it they say; "20th time is a charm"?
            • D
              dacad
              And my Plan B(lender) keeps growig...πŸ˜‰
              Yes Blender is a pain to understand and even find buttons (hell, there's even modeling stuff in the physics menus and vice versa...) but i still can't believe all the power it gives to the users.
              BTW guys don't rely on 2.5 for comercial work. It still isn't production ready and mature enough.
              • thomthomT
                I'm amazed over how small the download Blender is. Where are they hiding all the bits and bytes?
                  Not so little πŸ˜’
                  Core prog is 15 megas πŸ˜‰
                  Total application is 50 Megas πŸ˜‰
                  • thomthomT
                    Not so little πŸ˜’
                    3dSMax2010: 1,4GB
                    • thomthomT
                      @thomthom said:
                      Not so little πŸ˜’
                      3dSMax2010: 1,4GB
                      Oh wait, that was just the 64bit stuff. 32bit stuff that also installed is another 1,3GB.
                      • P
                        pichuneke
                        I prefer to wait for the first beta, or even the first official version. It will be Blender 2.6 in the middle of next year.
                        Forgive my spanglish...
                          Anim8or who makes quasi the "same" πŸ˜‰ than 3Dmax is less than 2 Megas πŸ’š
                          Modeling Rendering Animation 😎
                          Small is beautiful β˜€
                          • R
                            remus
                            For comparison, the SU free download is 36mb to blenders 18mb. Not bad in my book.
                            Theres a release log here if anyone wants to check out.
                            • thomthomT
                              Ok. I managed to get into Edit Mode for the selected object. (Tab)
                              But how do you select a face?
                              I only seem to be able to select vertices (by right clicking)
                              hm... RTFM to be able to select a face?
                              • W
                                Whaat
                                I've been starting to use Blender 2.49 a lot more lately. It was always completely frustrating trying to do anything but now I have finally learned enough to start to enjoy using it.
                                Here are a couple Blender 2.49 tips for SketchUp users (not sure if these all apply to 2.5):
                                • Go to User Preferences (if you can find it πŸ˜‰ ) and change the view rotation to 'Turntable' and select with to 'Left Mouse'
                                • View orientation controls are all with the numeric keypad
                                • press 'b' to Window Select
                                • press 'g' to move, 'r' to rotate and 's' to scale an object, then press x,y,or z to constrain along axis
                                • 'tab' goes to edit mode (like double clicking on component in SketchUp)
                                • hover your mouse over the UI buttons to find out what they do
                                • Don't even think about getting into materials and material editing unless you RTFM (my biggest mistake)
                                Oh, and to select a face in edit mode, look for a series of buttons at the bottom of the window to switch between vertex, edge, and face select mode
                                • thomthomT
                                  Ah hah! ahahaha!
                                  Ok - so where's the inference? Or rather, how can I extrude to a given vector, like perpendicular to the face I have selected?
                                  Also, is it correct that selecting is done by right clicking?
                                  When I select faces it often selects faces behind the front one...
                                  • EarthMoverE
                                    EarthMover
                                    Thomthom, try selecting four verticies of a box and hit the "E" key and choose extrude region. Also use "S" key for scale. Make an obscure rectangular shape by extruding & scaling multiple times, then while still in edit mode, assign a "subsurf" modifier to the mesh and take the levels up to 4 or 5. This is similar to SDS for su. Continue to modify the subsurf and affect the subdivided geometry. Notice the speed.
                                    Also, to select, use the RMB. To add to selection, use Shift+RMB. To quad face loop select, ALT+RMB
                                    "A" to deselect all.
                                    That's about all I remember from the 5 hours of tutorials I watched a few weeks ago.
                                    Content Creator at Skapeup
                                    • R
                                      remus
                                      Thom, couple of tips to help when selecting faces: theres a little dot in the middle of each face, if you click near that its much more likely to select the face your going for. you can also occlude geometry (the SU equivalent of turning off transparency) by clicking the little button one along from the vertex/edge/face select buttons.
                                      • thomthomT
                                        Aaah! Hey - I can build stuff! Thanks guys..
                                        Can't seem to find the Undo though. Not does Ctrl+Z work...
                                        • EarthMoverE
                                          EarthMover
                                          Michalis posted a link to some really good Blender tutorials in one of his early threads. The tutorials included the modeling of a frog. Anyone have a link? I can't seem to find the thread.
                                          • R
                                            remus
                                            ctrl+z works for me...i wonder if it depends on whether your in edit mode or not?
                                            • 1 / 2
