    Blender 2.5 Alpha 0
    extensions
    28 Posts 9 Posters 5.1k Views 9 Watching
      Anim8or who makes quasi the "same" πŸ˜‰ than 3Dmax is less than 2 Megas πŸ’š
      Modeling Rendering Animation 😎
      Small is beautiful β˜€
        remus
        For comparison, the SU free download is 36mb to blenders 18mb. Not bad in my book.
        Theres a release log here if anyone wants to check out.
          Ok. I managed to get into Edit Mode for the selected object. (Tab)
          But how do you select a face?
          I only seem to be able to select vertices (by right clicking)
          hm... RTFM to be able to select a face?
          • W Offline
            Whaat
            I've been starting to use Blender 2.49 a lot more lately. It was always completely frustrating trying to do anything but now I have finally learned enough to start to enjoy using it.
            Here are a couple Blender 2.49 tips for SketchUp users (not sure if these all apply to 2.5):
            • Go to User Preferences (if you can find it πŸ˜‰ ) and change the view rotation to 'Turntable' and select with to 'Left Mouse'
            • View orientation controls are all with the numeric keypad
            • press 'b' to Window Select
            • press 'g' to move, 'r' to rotate and 's' to scale an object, then press x,y,or z to constrain along axis
            • 'tab' goes to edit mode (like double clicking on component in SketchUp)
            • hover your mouse over the UI buttons to find out what they do
            • Don't even think about getting into materials and material editing unless you RTFM (my biggest mistake)
            Oh, and to select a face in edit mode, look for a series of buttons at the bottom of the window to switch between vertex, edge, and face select mode
              Ah hah! ahahaha!
              Ok - so where's the inference? Or rather, how can I extrude to a given vector, like perpendicular to the face I have selected?
              Also, is it correct that selecting is done by right clicking?
              When I select faces it often selects faces behind the front one...
              • EarthMoverE Offline
                EarthMover
                Thomthom, try selecting four verticies of a box and hit the "E" key and choose extrude region. Also use "S" key for scale. Make an obscure rectangular shape by extruding & scaling multiple times, then while still in edit mode, assign a "subsurf" modifier to the mesh and take the levels up to 4 or 5. This is similar to SDS for su. Continue to modify the subsurf and affect the subdivided geometry. Notice the speed.
                Also, to select, use the RMB. To add to selection, use Shift+RMB. To quad face loop select, ALT+RMB
                "A" to deselect all.
                That's about all I remember from the 5 hours of tutorials I watched a few weeks ago.
                Content Creator at Skapeup
                  remus
                  Thom, couple of tips to help when selecting faces: theres a little dot in the middle of each face, if you click near that its much more likely to select the face your going for. you can also occlude geometry (the SU equivalent of turning off transparency) by clicking the little button one along from the vertex/edge/face select buttons.
                    Aaah! Hey - I can build stuff! Thanks guys..
                    Can't seem to find the Undo though. Not does Ctrl+Z work...
                      EarthMover
                      Michalis posted a link to some really good Blender tutorials in one of his early threads. The tutorials included the modeling of a frog. Anyone have a link? I can't seem to find the thread.
                        remus
                        ctrl+z works for me...i wonder if it depends on whether your in edit mode or not?
                          EarthMover
                          Undo might be broken in the 2.5 release. Ctrl Z works in 2.49. I use the portable version and it works great.
                          Also another good tip is the "K" key. Use it to knife or loop cut. Since there is no "pencil" tool in quad modeling programs, use the loop cut to divide a face in the appropriate sections and create windows and such. Boolean modifier also works well. Loop cut is also good to add some "weight" to an edge that will be subdivided.
                          Personally I'd rather use sketchup for architectural stuff any day of the week. Nothing beats the tape measure / line tool combo. For organic shapes, Blender is the best of the "FREE" apps.
                          Remus, how do you "box" select in Blender? (drag a selection window?)
                            Some videos tutorial πŸ˜‰ (for 2.5 and 2.49)
                              EarthMover
                              THanks for the tutorial link Remus. Wow, 2.5 looks a lot like Modo.
                              • EscapeArtistE Offline
                                EscapeArtist
                                I was just going to start complaining that I'd started to figure out where everything was in the old Blender when I saw the new GUI open up. I looked around and started to find things much more easily (the old GUI was a PITA to figure out, I've been playing with Blender since 1.somethingorother and still haven't got it all right) and was turning that cube into the Venus de Milo in no time flat.
                                No, not really. But I do think the new layout is much better.
                                All these improvements and it makes me think that they're going to start charging for this stuff soon.
                                EDIT: OK, now I'm getting frustrated - where's my space-bar menu? My right/left click menu? My verticies/faces/edges selection? They moved them!
                                EDIT x 2: Figured it out. I'm loving this new setup! They got rid of the annoying movement selection, and now it extrudes on axis automatically! Fantastic!
                                  EarthMover
                                  Found the tutorials I was referring to. Not specific for 2.5, but a really good run down about blender functionality. - http://www.gryllus.net/Blender/3D.html
                                  Also found the box select option - "B" key - duh! Also tap B key twice to bring up circle select. Scroll wheel to change the size of the selection circle.
                                    EscapeArtist
                                    I gotta ask, where'd the plugins go? I threw some scripts in the usual place, but I can't find anything in the menus that will run a plugin.
                                    • 1 Offline
                                      11zulu
                                      Hiya
                                      Good video walkthrus are available here:
                                      Error 404 (Not Found)!!1
                                      (blender3dvideos.blogspot.com)
                                      and here is a series of walkthrus:
                                      At the following is is a whole bunch of other walkthrus:
                                      http://blenderlabrat.blogspot.com/
                                      The link below also has a simple walkthru as well:
                                      Bad Request
                                      (www.totallyblended.com)
                                      And on Vimeo, one for Maya users:
                                      http://www.vimeo.com/7040523
                                      Laters
                                        remus
                                        Cheers 11zulu, always handy to have a good stack to go through when i've got a bit of spare time πŸ‘
