    Extensions and rubies doesn't load [Mac] [solved]
    26 Posts 9 Posters 3.7k Views 9 Watching
      tfdesign
      I've just updated to Snow leopard (this morning), and so far I'm very impressed with the overall performance- compared with Leopard. I've also updated to the very latest SU7 build- which seems fine now. Even this website page displays properly! πŸ˜„ πŸ˜„
      What was I worrying about? πŸ˜’ πŸ˜†
      Rest assured Andrew, you'll be the first to know if anything doesn't look right. πŸ˜„
      My book "Let's SketchUp!" Download from here
      • O Offline
        oic
        Hi folks, this is my first post to this forum...
        I am new to sketchup and just purchased a license for pro 8.
        My issue is related to this topic in that I am unable to install extensions/ruby scripts.
        Here is a screen shot of the error message:
        My operating system is OSX 10.6.8 (snow leopard), here is a screen shot of my disc settings:
        Still no banana however...
        Any advice would be greatly appreciated, I am not a computer wiz but I can follow instructions!
        Thanks kindly,
        Orion.
          @oic
          You forgot to tell us what it was you were trying to install, that generated the error-message... πŸ˜•
          Only RBZ archives can be auto-installed. ZIP and RB etc must be installed manually OR use thomthom's 'Simple Plugin Installer' tool, available from the Plugins index menu item above...
          Do you have full security permissions [read/write] to the SketchUp plugins folder?
          If not you can't add files into it...
          Try changing those...
          The correct plugins folder is Macintosh HD/Library/Application Support/Google Sketchup 8/Sketchup/plugins [NOT the 'user' one]
          You can run this line in the Ruby Console to double check that your installation is right:
          Sketchup.find_support_file('ocean_extension.rb', 'plugins') - this .rb script is supplied with SketchUp and is [or should be!] in the correct folder...
          • O Offline
            oic
            Thanks TIG,
            I had assumed that I did have read/write permissions for the plugins folder but had read only, now it works..
            these things always seem so obvious when solved.. β˜€
            this forum just saved me from a lot more faffing around,
            Cheers,
            O.
            • N Offline
              nordicventures
              I have the same problem as oic above but I'm very new to this stuff and and have no idea how to verify if I have read and write permission? I ran : Sketchup.find_support_file('ocean_extension.rb', 'plugins') in the ruby console and yes my plugins are in the right place. I still get the same "unknown error" message when trying to load a .rb or .rbz file of any kind. I have tried many different plugins and I'm about to shoot myself in the face.
              Please help soon.
                The resetting of your MAC's plugins folder's permissions to FULL Read/Write has been covered many times in the forums...
                Here's a good one http://sketchucation.com/forums/viewtopic.php?p=468689#p468689
                • 2 / 2
