    Getting rid of blotches
    renderpluginsextensions
    7 Posts 2 Posters 2.5k Views 2 Watching
    • holmes1977H Offline
      holmes1977
      hi
      Im having trouble getting rid of blotches on the white slidding above the garage door.
      If you have any other tips on how I can impove this image I'd love to hear them.
      Thanks for your help.
      http://i607.photobucket.com/albums/tt154/holmes1977_album/trial_post_01.jpg
      Exaggeration makes a dull story better.
        Some info on your render settings would help. Very hard just by guessing.
        But I take it you are using IR+LC?
          holmes1977
          hope this helps
          http://i607.photobucket.com/albums/tt154/holmes1977_album/settings.jpg
            holmes1977
            Im using free agents visopt
            Which uses
            -II
            -DMC
              Your IR max value is low. At least if the image you posted is the size you render in. Try -1 or 0.
                holmes1977
                Your a STAR Thomthom
                That did the trick
                  Note that once the IR is as good as you want it, if you choose to render twice the size, then you can reduce the min/max by one. If you render four times larger you can reduce min/max by four.
