Getting rid of blotches
hi
Im having trouble getting rid of blotches on the white slidding above the garage door.
If you have any other tips on how I can impove this image I'd love to hear them.Thanks for your help.
Some info on your render settings would help. Very hard just by guessing.
But I take it you are using IR+LC? -
hope this helps
Im using free agents visopt
Which uses
-II
-DMC -
Your IR max value is low. At least if the image you posted is the size you render in. Try -1 or 0.
Your a STAR Thomthom
That did the trick
Note that once the IR is as good as you want it, if you choose to render twice the size, then you can reduce the min/max by one. If you render four times larger you can reduce min/max by four.
