    Orbit about a specific axis
    13 Posts 10 Posters 9.3k Views 10 Watching
    • P
      PeterCharles
      Sometimes I get quite frustrated trying to orbit around my model to get the view I want.
      Is there a way to orbit around just one specified axis at a time???
        Just use Tool Axes
        Insert it in the middle of your object as you want πŸ˜‰
        • P
          PeterCharles
          Just use Tool Axes
          Surely that just changes the position of the axis. How does that enable me to orbit about just one of them?
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            Try moving the mouse horizontally only and you will obtain an orbit around the blue axis.
            Position the red axis horizontally and then, when moving the mouse only vertically, you will get an orbit around the red axis.
            Position the green axis horizontally and then, when moving the mouse only vertically, you will get an orbit around the green axis.
            Of course, this is not totally precise and you will have small movements around the other axes if your hand is not rock steady and even if you are rock steady, it is not perfect.
            To get really precise orientation around an axis, I would rotate the model with the Rotate Tool and use a standard view.
            Just ideas.
            • P
              PeterCharles
              So when the chips are down it can't be done.
              • N
                NewOne
                There is Mover
                It rotates by axis... just not with mouse.
                • jeff hammondJ
                  jeff hammond
                  i'm not quite sure what type of views you're going for but you might give this a try..
                  http://www.smustard.com/script/CameraControls
                  dotdotdot
                  • P
                    PeterCharles
                    πŸ’­
                    Maybe I'll just have to learn to use that Sandio 3D mouse then.
                    • R
                      remus
                      you could always just hold ctrl while your orbiting, this will turn of the 'turntable' effect you usually get.
                      • C
                        Cyberdactyl
                        Also, if you're working on a very complex model, in a specific area, get in the habit of making a 'scene' of that situation.
                        If you get even slightly disoriented, you can pop to a well known orientation to get your bearings.
                        • X
                          xrok1
                          Twilight has an awesome built in camera tool to rotate around a specific point. try the demo, you'll fall in love! πŸ˜‰
                          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                          • D
                            djh
                            Holding control while rotating should constrain the rotation?
                            • S
                              slbaumgartner
                              No. SketchUp's orbit has a notion of "gravity" by which it tries to keep the horizon line (duh!) horizontal. Holding ctrl (option on Mac) suspends this action and actually allows less constrained orbiting, the opposite of what is being requested!
