    Components
    12 Posts 5 Posters 977 Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      When I build a component out of 2 components,
      entities=model.entities
      entities.each do |e|
        if e.typename == "ComponentInstance"
          puts "Component; #{e.definition.name}"
        else
          puts e.typename
      can not see the original 2 components, but
      definitions=model.definitions
      definitions.each do |d|
        puts d.name
      can. "Model Info" corectly reports all the component instances in the model. Is there another procedure that I can use to find all the component instances other then by definitions?
      Is there a way to extract the information regarding the 2 original components, from the one that they are made into? I have tried but failed to do so.
      • Chris FullmerC Offline
        Yes! There is.
        So the model.entities collection is a collection of all TOP LEVEL entities. This is anything un grouped, and the components that are on the top most level. It does not return any components or geometry inside of groups/components. So your code:
          else
            puts e.typename
        Is going through all the top level entities and finding all top level components and listing their name. So in your case, you only had 1 top level component, that had 2 components inside of it.
        So just as the model has a list of entities, so does each group or component. You get them like this:
        my_comp_instance.entities
        And that returns all entities within that component. Which you can then iterate through and find all compononts in there. Somthing like this:
            puts e.entities.to_a
          else
            puts e.typename
        So now it will puts the entire entities collection of that componentinstance. You will want to then take that entities collection and sort through it, find all components and instances and start making an array of all found components/groups. Then work your way through your array of components, looking at their entities and adding all groups and components into your array.
        Did that make any sense? I think I worded it poorly. But that is the idea. Make a list of groups and components, then look at all those groups/components entities collections for and groups and components that they might contain. repeat until there are no more groups/components in your list that you compiled.
        Chris
        All my Plugins I've written
          .typename is slow - very slow.
          .is_a? is much quicker.
          if e.is_a?(Sketchup::ComponentInstance)
            honoluludesktop
            Thomas, Thanks, I now recall reading that somewhere.
            Chris, I understand the logic, but so far can't find the correct procedure. Will work on it tomorrow:-(
              I have never written a script that has to mine down through all the components the way I've vaguely described. So I'm sure i've missed some key things.
              Chris
              • TIGT Online
                You can get a component-instance.
                You can get that component-instance's definition.
                You can get a component-definition.
                You can get that component-definition's instances.
                A group is a special kind of instance.
                There is no built in method to get a group's definition - but it can be done in a convoluted way - there are other threads on this - group.real_parent will return it as below...
                class Sketchup;;Group
                  # Some times the group.entities.parent refer to the wrong definition. This method checks for this error and locates the correct parent definition.
                  def real_parent
                    if self.entities.parent.instances.include?(self)
                      return self.entities.parent
                    else
                      Sketchup.active_model.definitions.each { |definition|
                        return definition if definition.instances.include?(self)
                    end#if
                    return nil # Should not happen.
                  end#def
                end#class
                A model has entities.
                A group has entities.
                A component-definition has entities.
                A component-instance does not have entities - you must refer to its component-definition for these.
                Hope that's clear ❓ ☀
                  What "information" are you looking for? What are you trying to do?
                  You could scan the whole model, but that would be very inefficient. looping through model.definitions and getting the instances for each definition is the fastest and most efficient way to get to all the model's instances.
                    If you already have a reference to a component instance, and you want to find the other instance, then: myInstance.definition.instances
                      RickW
                      I think I remember reading that
                      e.instance_of? Sketchup::ComponentInstance
                      is even faster.
                      I concur. While recursion is elegant from a coding standpoint, it's grossly inefficient and prone to crashing SU. Best to find what you're looking for in the definitions.instances.
                      RickW
                      www.smustard.com
                        honoluludesktop
                        TIG, do I get it?
                        A component-instance, and that component-instance's definition.
                        model = Sketchup.active_model
                        selection = model.selection
                        selection.each do |i|
                          if i.is_a? Sketchup;;ComponentInstance
                            puts i.definition.name
                        A component-definition, and that component-definition's instances.
                        model.definitions.each do |d|
                          d.instances.each do |i|
                        model.entities.each do |e|
                          puts e.typename
                          d.entities.each do |i|
                            puts i.typename
                        Haven't worked with groups yet.
                        See image below, I am still unable to get the name of the component (small boxA within the big boxB) within a selection of the component that is both (boxC).
                        Thomas:
                        Am doing 2 things: First going through the API trying to learn how to ruby, and also trying to get a list of entities (including sub components) that are inside a specific component. Is myInstance.definition.instances what I have above?
                        RickW:
                        Good tips.
                        • TIGT Online
                          You missed out the variant...
                                  i.definition.entities.each{|ent|
                                    puts ent.class
                          This will show you that you can find component-instances inside a component, then you can get the instance's definition and then that's entities etc... If you have nested items you need to do make a 'def' that's reused to iterate through them...
                                   if ent.is_a? Sketchup;;ComponentInstance
                                     ent.definition.entities.each{|dent|
                                       puts dent.class
                                       ###etc
                            honoluludesktop
                            TIG, Got it, thanks:
                              puts "Component(s)"
                            	i.definition.entities.each do|j|
                            	  if j.is_a? Sketchup;;ComponentInstance
                            		puts j.definition.name
                            		j.definition.entities.each do|k|
                            		  if k.is_a? Sketchup;;ComponentInstance
                            			puts k.definition.name
                            Now, to organize as a proceedure to accomplish the above (3 levels) to the nth level:-}
