    Components
    12 Posts 5 Posters 1.2k Views 5 Watching
      @honoluludesktop said:
      if e.typename == "ComponentInstance"
      .typename is slow - very slow.
      .is_a? is much quicker.
      if e.is_a?(Sketchup::ComponentInstance)
      • honoluludesktopH
        honoluludesktop
        Thomas, Thanks, I now recall reading that somewhere.
        Chris, I understand the logic, but so far can't find the correct procedure. Will work on it tomorrow:-(
        • Chris FullmerC
          I have never written a script that has to mine down through all the components the way I've vaguely described. So I'm sure i've missed some key things.
            You can get a component-instance.
            You can get that component-instance's definition.
            You can get a component-definition.
            You can get that component-definition's instances.
            A group is a special kind of instance.
            There is no built in method to get a group's definition - but it can be done in a convoluted way - there are other threads on this - group.real_parent will return it as below...
            class Sketchup;;Group
              # Some times the group.entities.parent refer to the wrong definition. This method checks for this error and locates the correct parent definition.
              def real_parent
                if self.entities.parent.instances.include?(self)
                  return self.entities.parent
                else
                  Sketchup.active_model.definitions.each { |definition|
                    return definition if definition.instances.include?(self)
                end#if
                return nil # Should not happen.
              end#def
            end#class
            A model has entities.
            A group has entities.
            A component-definition has entities.
            A component-instance does not have entities - you must refer to its component-definition for these.
            Hope that's clear ❓ ☀
              Is there a way to extract the information regarding the 2 original components, from the one that they are made into? I have tried but failed to do so.
              What "information" are you looking for? What are you trying to do?
              Is there another procedure that I can use to find all the component instances other then by definitions?
              You could scan the whole model, but that would be very inefficient. looping through model.definitions and getting the instances for each definition is the fastest and most efficient way to get to all the model's instances.
                If you already have a reference to a component instance, and you want to find the other instance, then: myInstance.definition.instances
                  RickW
                  I think I remember reading that
                  e.instance_of? Sketchup::ComponentInstance
                  is even faster.
                  I concur. While recursion is elegant from a coding standpoint, it's grossly inefficient and prone to crashing SU. Best to find what you're looking for in the definitions.instances.
                  RickW
                  www.smustard.com
                  • honoluludesktopH
                    honoluludesktop
                    TIG, do I get it?
                    A component-instance, and that component-instance's definition.
                    model = Sketchup.active_model
                    selection = model.selection
                    selection.each do |i|
                      if i.is_a? Sketchup;;ComponentInstance
                        puts i.definition.name
                    A component-definition, and that component-definition's instances.
                    model.definitions.each do |d|
                      d.instances.each do |i|
                    model.entities.each do |e|
                      puts e.typename
                      d.entities.each do |i|
                        puts i.typename
                    Haven't worked with groups yet.
                    See image below, I am still unable to get the name of the component (small boxA within the big boxB) within a selection of the component that is both (boxC).
                    Thomas:
                    Am doing 2 things: First going through the API trying to learn how to ruby, and also trying to get a list of entities (including sub components) that are inside a specific component. Is myInstance.definition.instances what I have above?
                    RickW:
                    Good tips.
                      You missed out the variant...
                              i.definition.entities.each{|ent|
                                puts ent.class
                      This will show you that you can find component-instances inside a component, then you can get the instance's definition and then that's entities etc... If you have nested items you need to do make a 'def' that's reused to iterate through them...
                               if ent.is_a? Sketchup;;ComponentInstance
                                 ent.definition.entities.each{|dent|
                                   puts dent.class
                                   ###etc
                      • honoluludesktopH
                        honoluludesktop
                        TIG, Got it, thanks:
                          puts "Component(s)"
                        	i.definition.entities.each do|j|
                        	  if j.is_a? Sketchup;;ComponentInstance
                        		puts j.definition.name
                        		j.definition.entities.each do|k|
                        		  if k.is_a? Sketchup;;ComponentInstance
                        			puts k.definition.name
                        Now, to organize as a proceedure to accomplish the above (3 levels) to the nth level:-}
