    ! Help
    8 Posts 6 Posters 882 Views 6 Watching
    • H
      haynesc
      hi can someone provide mw with some help in order to create these forms asap...
      thanks
      • numbthumbN
        numbthumb
        Hi!
        It looks like you could accomplish that with some twisting.
        Take a look at the FredoScale plugin ( I think that the current version is 2.0h )
        And what is this? ( I am just curious )
        Cheers!
        Comfortably numb...
        • M
          mac1
          Here is my feeble first attempt, did not know all the dimensions so took some liberty and off cpourse does not exactly meet your pics. The approach used:
          1. Drew ellipse for the bowl , 30x60 mm;
          2. Used SoapSkin and Bubble ruby, free download, to create bowl surface. You can play with segments and pressure to control what you want;
          3. Drew handle and intersected with bowl to get and intersection profile the used arc tool to get something looking close to what you want.
            Have fun 👊
          scoop.skp
          • soloS
            solo
            This should be a snap with the FFD plugin.
            http://www.solos-art.com
            • K
              kwistenbiebel
              Tricky one.
              FredoScale (bend option), as good is it is, won't help in this case.
              FFF might work indeed, but I find its output unpredictable and in may cases doesn't work at all.
              What Mac1 made using Soap Skin Bubble hardly resembles the thing haynesc is aiming for.
              I am interested to see some more suggestions....
              • D
                dedmin
                • M
                  mac1
                  @dedmin said:
                  [attachment=0:2esq3wq9]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:2esq3wq9]
                  dedmin
                  I knew it was not close! Thought the soapskin bubble plugin my help him
                  Good job.
                  How about a little explaination how it was made. In my effort have had problems with the out of normal plane arcs to get the proper surface 😞
                  • D
                    dedmin
                    http://tranz.it/load.php?id=xILh8DHUlEG4pnW2433431
