    ! Help
    8 Posts 6 Posters 765 Views 6 Watching
    • H Offline
      haynesc
      hi can someone provide mw with some help in order to create these forms asap...
      thanks
      • numbthumbN Offline
        numbthumb
        Hi!
        It looks like you could accomplish that with some twisting.
        Take a look at the FredoScale plugin ( I think that the current version is 2.0h )
        And what is this? ( I am just curious )
        Cheers!
        Comfortably numb...
          mac1
          Here is my feeble first attempt, did not know all the dimensions so took some liberty and off cpourse does not exactly meet your pics. The approach used:
          1. Drew ellipse for the bowl , 30x60 mm;
          2. Used SoapSkin and Bubble ruby, free download, to create bowl surface. You can play with segments and pressure to control what you want;
          3. Drew handle and intersected with bowl to get and intersection profile the used arc tool to get something looking close to what you want.
            Have fun 👊
          scoop.skp
          • soloS Offline
            This should be a snap with the FFD plugin.
              kwistenbiebel
              Tricky one.
              FredoScale (bend option), as good is it is, won't help in this case.
              FFF might work indeed, but I find its output unpredictable and in may cases doesn't work at all.
              What Mac1 made using Soap Skin Bubble hardly resembles the thing haynesc is aiming for.
              I am interested to see some more suggestions....
                dedmin
                  mac1
                  @dedmin said:
                  [attachment=0:2esq3wq9]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:2esq3wq9]
                  dedmin
                  I knew it was not close! Thought the soapskin bubble plugin my help him
                  Good job.
                  How about a little explaination how it was made. In my effort have had problems with the out of normal plane arcs to get the proper surface 😞
                    dedmin
                    http://tranz.it/load.php?id=xILh8DHUlEG4pnW2433431
