    Section pane fixed distance from camera??
    5 Posts 4 Posters 551 Views 4 Watching
    • P
      Pete
      Does anyone know if it is possible to place a section pane a fixed distance from the camera so that as I rotate a model I can see a cross section at every point of view. This would be very useful when designing interiors. Thanks
      • R
        remus
        I dont think its currently possible. As an alternative you could try experimenting with using scenes to control section cuts, i imagine with some playing around you could get a pretty powerful setup up and running.
        • thomthomT
          I'd do what remus suggest. I often set up "working scenes" in my models. Scenes that only changes axis location, or layer visibility etc.
          • M
            mac1
            Not as elegant as the scene approach but, maybe a working solution for you. The section plane can be moved and rotated and, you can align view to that plane.
            • M
              mac1
              Sorry tomthom pick the wrong box this should have been for pete 😐
