    Section pane fixed distance from camera??
    5 Posts 4 Posters 350 Views 4 Watching
      Pete
      Does anyone know if it is possible to place a section pane a fixed distance from the camera so that as I rotate a model I can see a cross section at every point of view. This would be very useful when designing interiors. Thanks
        remus
        I dont think its currently possible. As an alternative you could try experimenting with using scenes to control section cuts, i imagine with some playing around you could get a pretty powerful setup up and running.
          I'd do what remus suggest. I often set up "working scenes" in my models. Scenes that only changes axis location, or layer visibility etc.
            mac1
            Not as elegant as the scene approach but, maybe a working solution for you. The section plane can be moved and rotated and, you can align view to that plane.
              mac1
              Sorry tomthom pick the wrong box this should have been for pete 😐
