    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 379.0k Views 71 Watching
      There shouldn't be any clashes - everything should be 'self-contained'...
      I have every plugin known to man, and then some more, so if anyone were to get a clash it'd be me πŸ˜•
      Have you tried Model Info > Statistics > Fix Problems...
      Or try selecting the rail/profile curve and the using edit > cut and paste-in-place - this sometimes reforms the curve if there's glitch in the model's database - do all four in turn.
      Another possible fix is to explode and immediately re-weld the curves in turn, and another fix is to group the curve, edit > copy, erase the original group, then paste-in-place and explode the replacement group back into its curve.
      Sometimes curves vertices get muddled and the algorithms in the scripts fail to order them no matter how hard they try, etc...
      Perhaps post the problem skp and let us all have ago too ?
      πŸ˜•
      • X Offline
        xrok1
        i could post the file but this is how simple it is. draw three arcs, pick profile rail rail same profile again, then i get all the message boxes but no result!
        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          have you try with a previus version of the plug?
          I have not yet the last version (no color of curves picked) 😳
          and that works fine β˜€
          • X Offline
            xrok1
            yes its never worked for me 😞 and like i said it does work with other installs of SU i have in oldProgramFiles folder left over from when i upgraded to win7.
              As a matter of interest, did you try it in XP compatability mode? Doubt it'll make any difference as it runs on my Win7 perfectly ok!
              But worth a shot to see if its Windows related?
              I had similar issue with 'Screw' ruby and Pilou's 'Fragmentation' plugin. Constant Bugsplat anytime i ran them. Ended up backing up 'Plugins' folder and reinstalling SU7.1. Worked fine after that? Don't know why and don't care.
              Really strange that it lets you complete the whole process but doesn't give any resulting geometry.
              • X Offline
                xrok1
                can't see it being a windows issue because
                but i tried the compatibility thing anyway... no luck!
                • X Offline
                  xrok1
                  grasping at straws here but i wonder if its not debabilizer? are there any other plugs that use this so i could check if they work?
                    The deBabelizer script is used by some other tools BUT I can't see how that'd mess up...
                    Do I understand correctly ? It doesn't make a mesh even when using the sample skp ?
                    Weird...
                    Have you tried downloading the whole zip file again and overwriting everything in Plugins and ../TIGtools etc ?
                    Can you publish a sample problem skp too ?
                    πŸ˜• πŸ˜•
                    • U Offline
                      Ultimatez 32
                      Hi TIG,
                      I have the same problem with rocky, I'm still using the old version, haven't updated yet. It works though when the first v2 came out, but then never work for me. Here's an video showing it: http://www.screencast.com/users/ultimatezod/folders/Jing/media/12a5229d-30a5-4b24-9b91-7a4220682320
                      ultimatez
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                      • U Offline
                        Ultimatez 32
                        Hi TIG,
                        Here's what the ruby console says if I click one of the message boxes 'Yes'
                        ultimatez
                          This is an even deeper mystery... the error reports that 'Line 871' refers to something that was previously deleted - That line is actually a commented out line [###] within a 'model.start_operation' test for the 'erase_coplanar_edges' sub-section ??? Have you edited the file ? There was a glitch with original curve deletion in some tools etc, but that was fixed a while ago in a re-release of all of the tools.
                          Here's the latest EEbyRails ruby file - extrudeEdgesByRails.rb - replace the one in Plugins [temporarily] and see what happens...
                          Can I suggest that you get the full current zipped set here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          and reinstall everything, overwriting all existing files/sub-folders when prompted...
                          Can you publish the skp that has the problem, or is it a pandemic !
                          πŸ˜•
                          • U Offline
                            Ultimatez 32
                            Hi TIG,
                            It still doesn't work when I downloaded the entire zip file again, here's the ruby code message when I click yes on the first message box and also the skp file attached.
                            eebr_bug.skp
                            ultimatez
                            • kenK Offline
                              ken
                              I see this person has Vista. I know that I had a problem with Vista also. For some reason, there is another directory that will store plugins, and so as you install other newer updates, they go into this other directory, Program Data, and so the plugin in Sketchup's plugin directory does not get updated.
                              Note, sorry I can't be more clear, I just know that I found some of my missing plugin in this other directory, Program Data and not in the Program file directory.
                              Ken
                              • U Offline
                                Ultimatez 32
                                Hi Ken,
                                I checked my program data and it does not include a sketchup plugin directory.
                                ultimatez
                                  Good point.
                                  Seems it's an 'install' rather than a tool problem...
                                  There's nothing wrong with the SKP - as the attached image shows it EEbyRails meshed in a second!
                                  With Vista you have to do stuff as an Administrator and if you try to write files to a folder within a folder in Programs Files it often appears to do it but puts it into a side 'Compatibility' files folder set up. It's a pain - it does it without telling you !
                                  I suspect that you have some out of date files that aren't getting updated although it looks like they are...
                                  You can change the access rights to the Plugins folder as an Admin under Properties - then it might work OK
                                  To force it extract the zip files into a folder on your Desktop.
                                  Open the .../Sketchup 7/Plugins/ folder.
                                  Then open the folder you just made on your Desktop.
                                  Select everything in that folder including the sub-folder[s] and drag and drop the lot into Plugins.
                                  You might be asked if you want to do it as an administrator [say Yes], you will be asked if you want to merge folders and overwrite files say Yes to everything, ticking the box to do NNN similar...
                                  NOW you should have a 'pure' installation.
                                  Try opening SUp again and using EEbyRails again...
                                  • X Offline
                                    xrok1
                                    TIG, i ran the new file you uploaded and no change. i get the exact same error message as ultimate. i don't think its an install thing cause like i said its works on 2 old installs on the same computer and i always use the admin accout to log in to my computer.
                                      Have you tried the clean install and ensured that there are no 'compatibility file' issues ?
                                      It's the folder permissions for Sketchup../Plugins/ that's the possible problem...
                                      If 'no one' is allowed to write to the folder Vista files things away in a parallel compatibility folder that you can then move stuff from, BUT it doesn't flippin' tell you what it's done !!! you have to search yourself.
                                      Use Notepad to open the new ruby I posted, from your desktop downloaded copy and also do it with the equivalent file in Plugins... are their contents exactly the same ?
                                      • X Offline
                                        xrok1
                                        well they appear the same but it would help if i knew some of the differences so i could use edit>find.
                                        can you tell me what other rubies use debabalizer so i could check my theory. btw, i might not have mentioned but non of your extrude plugins work for me.
                                        • X Offline
                                          xrok1
                                          just tried clean install, no difference. 😒
                                            Scroll down to the 'version' details...
                                            It won't be deBableizer that's causing the problem...
                                            Aaah... If nothing is working perhaps you are not putting files in the right places ?
                                            Are you putting the ruby scripts into the Plugins folder and all of the other files in to Plugins/TIFtools or the sub-folders.
                                            If you have any files in the wrong place please remove them...
                                            You must extract all of the files from the zip in the same folders as they are zipped in...
                                            Here is what the zip looks like... EE_Files.PNGThese should go into the Plugins folder.
                                            The zip's TIGtools subfolder contains these files [the PC's folder might also contain files for other tools]...TT_files.PNGThe sub-subfolder TIGdonations_files folder had two files in it too...Capture.PNG
                                            So to recap... the files/folders in the zip should be extracted and be matched exactly with those in the Plugins folder - any others in the 'wrong' place need removing...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 16 / 20
