    Select and snap????
    8 Posts 6 Posters 665 Views 6 Watching
      3eighty
      This is probably a dream...Is there a way or a Ruby to select "A" (componet)and then click on a point on "B" (componet)and have "A" snap to that spot on "B"?
      Example: Machine Gun = "A" and airplane wing = "B"
      Select "A"
      Click a point on "B"
      Machine gun snaps to that point.....
      I know 🀣
      • Chris FullmerC
        Yes, its called the move tool πŸ˜„
        ACtivate it, click on comp A, then click on comp B - in the exact spot you want A to snap to, an voi-la! Its all snapped together πŸ˜„
        Chris
        All my Plugins I've written
        • TIGT
          In addition to that... IF you don't have any obvious snappable vertices etc in these components but you still want a 'snap' point in them then place a very short piece of line at the spot in each component where they are to 'mate' - so it's effectively a snap-dot [Tip: Entity Info it to a very small length (0.1mm?)]... then Move one component by picking its 'snap-dot' and snap to the equivalent 'snap-dot' in the other component.
            3eighty
            Dreams do come true..Thanks guys..Something new to learn every day..
            • T
              tim
              Or use a guide point. Pretty much tailor-made for this purpose.
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                If you want a guide point without a dashed line try this:
                1 - Draw a circle.
                2 - Use "Point at center".
                3 - Delete the circle.
                This guide point can be moved and copied.
                Just ideas
                • TIGT
                  The problem with using a 'guide point' is that if you choose the Edit item to Delete Guides then they ALL go even those inside Components... then you're screwed ! That's why suggested a small piece of line as a 'snap-dot' - it's not deleted by this...
                  • Alan FraserA
                    Alan Fraser
                    http://forums.sketchucation.com/viewtopic.php?f=18&t=5692&p=32649
                    3D Figures
