How do u render jpeg in Vray
hi,
How do i render jpegs in Vray for Sketchup. If I stick a jpeg of a store logo for example on my sketchup model, it doesn't show up in the render.
thanx -
Did you import that as an Image?
(When you select it, does the Entity Info window say "Image"?)At the moment VfSU doesn't render images. You must make it into a material You can quickly do that by exploding it.
hi thomthom
thanx alot man!
exploding the image did the trick, thats all i needed... -
How do I explode a jpg image??? Thanks
You just revived 8 years old topic
Right click to image > Explode
Register LoginAdvertisement
