    [Plugin] Make Named Group
    25 Posts 13 Posters 35.3k Views 13 Watching
    • thomthomT
      By request-ish: http://forums.sketchucation.com/viewtopic.php?f=180%26amp;t=23567
      (Code sample turned out to become full plugin.)
      Adds Make Named Group to the Edit menu.
      404 Not Found
      (sketchucation.com)
      • A
        alz
        Nice! I like the Layer addition.
        What about defaulting it so the GROUP NAME field is highlighted first? Then you can immediately enter a group name, instead of selecting it, then naming it?
        • thomthomT
          hm... don't think I have control of that. Unless I swap the order of them.
          Or I could make a custom window. Will see.
          • TIGT
            Unfortunately with the basic inputbox the last set field is always highlighted...
            • thomthomT
              I filed a bug on this.
                In this order of idea: a ruby who take the name of a group (or Component) selected then create the same "Layer name" and put the group (or Component) in this new Layer named will ne fine πŸ˜„
                • thomthomT
                  Untested, but this should place all groups/components into a layer based on their name.
                  model = Sketchup.active_model
                  sel = model.selection
                  sel.each { |e|
                    next unless e.is_a?(Sketchup;;Group) || e.is_a?(Sketchup;;ComponentInstance)
                    model.layers.add(e.name) if model.layers[e.name].nil?
                    e.layer = model.layers[e.name]
                  • D
                    din_wiesel
                    Would it be possible to put the entry from the "Edit Menu" to the context menu?
                    greets din
                    • thomthomT
                      I will see if I can add support for UI Manager - so you can choose. There are people who prefer not to have their context menu filled with more items. So it's not easy to get a balance. But when the user can choose then it's not an issue any more.
                      • J
                        JGA
                        Thanks for the plugin, a great idea.
                        Regards,
                        JGA
                        Regards,
                        JGA
                        • D
                          dedmin
                          I just saw this - very useful! I started recently using groups instead of components and I'm using this wonderful plugin - http://forums.sketchucation.com/viewtopic.php?t=9318
                          If there is a way to combine them into one - perfect!
                          • thomthomT
                            Is there different functionality?
                            • D
                              dedmin
                              • thomthomT
                                • D
                                  dedmin
                                  It has a drop-down list of 20 names to choose from
                                  • thomthomT
                                    That seems very specific...
                                    I still don't see what combination it is you're looking for.
                                    • D
                                      dedmin
                                      Your plugin plus a drop-down list for the group names. Jim's plugin allows You to write 20 most used names in a text file for later use - useful in many fields where the parts are common - furniture and the like.
                                      • utilerU
                                        utiler
                                        Hey Thomas, love your plugins....
                                        With this one; do you think you could have the group added to a layer of the same name? If no layer, ask the user do you want to add a layer? Would be a great timesaver.....
                                        Thanks.
                                        A
                                        Just Curious...
                                        • bagateloB
                                          bagatelo
                                          Thanks.
                                          A
                                          It would be interesting if there was a box or drop down menu where it appeared the possibility to create and now include the object in a layer with the same name.
                                          Create components instead of groups might be interesting too.
                                          • utilerU
                                            utiler
                                            Thanks.
                                            A
                                            Thom?
                                            Just Curious...
                                            • 1 / 2
