    [Plugin] Make Named Group
    25 Posts 13 Posters 35.3k Views 13 Watching
      din_wiesel
      Would it be possible to put the entry from the "Edit Menu" to the context menu?
      greets din
        I will see if I can add support for UI Manager - so you can choose. There are people who prefer not to have their context menu filled with more items. So it's not easy to get a balance. But when the user can choose then it's not an issue any more.
          JGA
          Thanks for the plugin, a great idea.
          Regards,
          JGA
          Regards,
          JGA
            dedmin
            I just saw this - very useful! I started recently using groups instead of components and I'm using this wonderful plugin - http://forums.sketchucation.com/viewtopic.php?t=9318
            If there is a way to combine them into one - perfect!
              Is there different functionality?
                dedmin
                    dedmin
                    It has a drop-down list of 20 names to choose from
                      That seems very specific...
                      I still don't see what combination it is you're looking for.
                        dedmin
                        Your plugin plus a drop-down list for the group names. Jim's plugin allows You to write 20 most used names in a text file for later use - useful in many fields where the parts are common - furniture and the like.
                        • utilerU
                          utiler
                          Hey Thomas, love your plugins....
                          With this one; do you think you could have the group added to a layer of the same name? If no layer, ask the user do you want to add a layer? Would be a great timesaver.....
                          Thanks.
                          A
                          Just Curious...
                          • bagateloB
                            bagatelo
                            Thanks.
                            A
                            It would be interesting if there was a box or drop down menu where it appeared the possibility to create and now include the object in a layer with the same name.
                            Create components instead of groups might be interesting too.
                            • utilerU
                              utiler
                              Thanks.
                              A
                              Thom?
                              Just Curious...
                              • G
                                Goonster
                                Great plug in.Thanks. 😉
                                Ive assigned G' as a shortcut to it so I don`t have to keep going to the Edit menu.
                                • V
                                  veerlexyz
                                  Thanks a lot for this plugin.
                                  I would love to see this plugin "Make Named Group" in the right-click-menu.
                                  Is that possible?
                                    Is that possible?
                                    It is possible - but if I where to add it I'd get requests about removing it from people who want to reduce the amount of items in the context menu. Right now I don't have the time to make a UI for controlling this option.
                                    • T
                                      tula1847
                                      Hello just tried to download and says the .rb file is locked. How do I unlock I have a macbook pro.
                                      • K
                                        kaas
                                        Just 'discovered' this plugin. Added an array with often used groupnames (SFB codes) which is displayed in the dropdown list instead of the layer names and this speeds up my workflow quite a bit. Many thanks for this gem Thom!
