    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 266.4k Views 32 Watching
      Rhettsmiller
      @plot-paris said:
      hey Chris. I am afraid, the buttons of the toolbar end up blank.
      the zip file, you posted contains a ruby file called 'clf_center_on_origin.rb' and a folder with the Camera Recorder files.
      within this folder there is the camera recorder ruby, several images and an empty folder called 'images'.
      but no matter, where I placed the images (within the images folder. or the images folder directly in the plugins folder) it doesn't seem to be working 😞
      How was this resolved?
      Rhett
      • Chris FullmerC Offline
        arg, I responded to this, and then lost connection or something and it lost my reponse....oh well. I'll try again (plus the pm's we've been sending back and forth).
        Essentially the problem they saw here was caused by something else, I forgot a file.
        I just asked in my PM if you have podium installed (its another plugin that apparenetly can cause problems with plugin installation locations?). Lets take the onversation out of the PM area and here, just in case others can chime in with some Mac expertise.
        Anyhow, you might need to upload a screenshot of your plugins floder so I can see what's going on.
        Chris
        All my Plugins I've written
          No, you don't need podium installed. I had seen in another thread that it might complicate you mac installation folders or something.
          So I would say that the best thing to do now would be to send a upload a screenshot of your plugins folder, and maybe one of the inside of the clf_camera_recorder folder also.
          Chris
            rod1233
            Hi Chris
            I think I could not explain the problem. Although attaching the image.
            When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
            Hee this problem. 😞
            Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
            Tried to get rid of this problem but to no avail
            Thank you
              I have a new thought Rod. I bet it is a problem with "compatibility files".
              Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
              Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
              Then once you are sure there are no camera recorder files or folders, then reinstall them.
              Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
              Chris
                rod1233
                Hi Chris
                Thank you for the efforts
                It tried to explained to me earlier.
                But unfortunately the problem still exists. 😞 😞 😞
                Please search for a solution
                rod
                  Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
                  Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
                  Chris
                    rod1233
                    Hi Chris
                    I've done it and you delete all the contents of the folder plugins
                    And you do Install only the camera recorder plugin.
                    But the problem is not over yet
                    rod
                    • charly2008C Offline
                      charly2008
                      Chris, your camera tool is first class.
                      You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                      This Page Does Not Exist
                      Oops, looks like the page is lost.
                      (gromada.com)
                      Supported formats:
                      AC3, Dolby Digital compatible
                      AVI / DIVX / IVF, Windows Audio Video Interleaved
                      BAY, Bayer Image
                      BMP / DIB, Windows Device Independent Bitmap
                      CINE, Vision Research CINE, (read/uncompressed only)
                      FLC / FLI, Autodesk FLIC/FLIC-Pro
                      GIF, Graphics Interchange Format
                      HAV, High quality Audio Video
                      JP2, JPEG-2000 File Format / CodeStream
                      JPEG, Joint Photographic Expert Group
                      MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                      MPEG, Moving Pictures Expert Group, MPEG-1/2
                      OGG, OggVorbis Audio
                      OGV, OggVorbis Video/Audio
                      PCX, Zsoft Paintbrush
                      PNG, Portable Network Graphics
                      PNM / PPM, Portable Image
                      RAS / SUN, Sun Raster Image
                      RGB / SGI, Silicon Graphics Image
                      TGA, Truevision Targa
                      TIFF, Tagged Image File Format
                      WAV, Windows Wave Sound
                      * WMA, Windows Media Audio
                      * WMV, Windows Media Video
                      XPM, X-Pixmap
                        @rod1233 said:
                        Hi Chris
                        rod
                        Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                        Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                        Chris
                          Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                          Chris
                            rod1233
                            Chris
                            I did that and the problem is still.
                            Note: Windows in English, and also to the program in English
                            I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
                            Does this lead to error
                            rod
                              Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
                              Chris
                                rod1233
                                Chris
                                Here's what you requested
                                This folder contains the files
                                  rod1233
                                  Chris
                                  Where are you?
                                  I hope you of what is new
                                  rod
                                    rod1233
                                    Chris
                                    Where are you?
                                    rod
                                      rod1233
                                        Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                                        Chris
                                          OK, it is all installed right, thanks you so much for uploading that.
                                          One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                                          Chris
                                          PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                                          • PixeroP Offline
                                            Pixero
                                            Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                                            It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                                            Pleeeeaaase? πŸ˜„
                                            • 6
                                            • 7
                                            • 4 / 7
