    Applying Material to a layer
    6 Posts 5 Posters 15.9k Views 5 Watching
    • L
      layziefj
      I've been trying to apply a material to a layer and it doesnt seem to work.
      I import drawings from vectorworks and have objects on layers.. the glass for my windows are on a particular which i want to texture..
      is there a plugin required for this operation? or can be done with the existing sketchup tools..
      sorry if my question seems broken up.. im kinda in a rush.. cheers 😎
      • Alan FraserA
        Alan Fraser
        You just click the swatch next to the layer and it brings up the same material editor that you have in the material browser. You can then assign a different colour to the layer or select an image.
        You do need to switch to colour by layer mode, before you can see it, though.
        3D Figures
        • honoluludesktopH
          honoluludesktop
          TIG, that sounds like a neat plugin, You import, and rewrite the dxf. I will have to look at and study your code. Thanks.
          • TIGT
            I wrote a tool [DXFlayercols.rb - should be on the ruby forum somewhere...] that works if the import was a DXF you reimport the DXF with the tool and it assigns the original CAD color to the layer [within limits]. It can't import images/textures but at least the colors are correct and you can manually change the layer color to include a texture to suit
            • L
              layziefj
              thanks for the help guys.. yea that plugin is probably what i need.. will try it out and post back.. cheers guys β˜€
              • T
                tim
                @layziefj said:
                If you're wanting to apply a certain material to everything on a certain layer then
                turn off all other layers
                select all
                apply material
                turn other layers back on
