    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 210.8k Views 65 Watching
    • utilerU Offline
      utiler
      @thomthom said:
      btw, a4chitect: why do you have to doubleclick? Why not normal click like the regular PP?
      I thought the same thing, TT.
      Just Curious...
        rv1974
        Hi ar4itect I think your 'to do' list misses multiple adjasent\non adjacent faces push-pull.
        It'd be special case of Fredo's JPP. BTW While ago I asked him to implement it but unfortunatly it didn't happen.
        • plot-parisP Offline
          plot-paris
          oh, and to make it the almighty super tool, you could enalbe push/pull of more than one selected face simulaneously, making it a lot faster to do extrude several faces with the sam distance (something that I always wanted the push/pull tool to be capable of) 😄
          • erikBE Offline
            erikB
            a4chitect,
            very usefull ruby, well done !
            For me the possibilty to control the offset by means of the VCB is the one thing that is missing to make it a true replacement for the 'standard' push pull tool. (But it is already in the to do list !! 😉 )
            Thanks for sharing,
            erikB
            • david_hD Offline
              david_h
              okay . .this is total awesomenicity. Any possible way it could be written to be accessed from a right-click like JPP? That would just be cherry.
              THx,
              D
              • MALAISEM Offline
                MALAISE
                Yeee! Thanks a lot for this plugin 👍
                MALAISE
                  matteo
                  oooh!
                  “The one fact about the future of which we can be certain is that it will be utterly fantastic” – Arthur C Clarke
                  “The one fact about ruby coders of which we can be certain is that next ruby plugin will be utterly fantastic” – Matteo Bignozzi
                  thank you a lot arc4tect
                  hire me: http://www.nonsolo3d.it/ !
                  • EscapeArtistE Offline
                    EscapeArtist
                    Fantastic tool. I've been wishing for something like this for a while.
                    Nice job, I'm looking forward to any improvements you make.
                      dtrarch
                      a4
                      Simply just a WOW
                      Thank you
                      dtr
                        CADAddict
                        Very nice,
                        I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation?
                        Great job anyways!
                        http://www.cad-addict.com/
                        • urgenU Offline
                          urgen
                          ...very usefull! 👍 thank you!:)
                          --pupil forever...------
                          • utilerU Offline
                            utiler
                            @cadaddict said:
                            Very nice,
                            Great job anyways!
                            I like that idea, CADAddict!
                            Maybe something similar to the standard Pushpull with 'Ctrl' Pushpull leaving original face and edges....
                            What do you think a4chitect?
                            Just Curious...
                              a4chitect
                              i think you are talking about thd first entry in the todo list in the first post; such feature is planned.
                                Tricky! ☀
                                • halroachH Offline
                                  halroach
                                  Great and useful Plugin!
                                  I've got a few more to do's:
                                  1. What makes sketchup a great and fast program to use, is mainly the easy inferencing!
                                    As with the regular push-pull tool, you should be able to indicate exactly where the pulled plane will arrive to. The pulled plane should stick to existing lines/points which may intersect with it.
                                  [right now, I've noticed it only sticks if I start pulling the plain from a point (which is very difficult to determine if it's sticking or not) which is on a line (perpendicular to the pulled plain) which reaches the point I want to get to... (I imagine that's isn't very clear, I can add an image if needed) ]
                                  1. If two, or more of the side planes merge into a single point or a single line, it ought to stick there too.
                                    geometrically that would happen when one any one of the side planes gets to n-1 edges.
                                  2. when using the VCB - entering a number, pressing enter, and then entering another number, should act like other sketchup tools. It should act as though you're still pulling the same plane once. currently it keeps making more and more faces.
                                  3. when pressing TAB WHILE using the tool - at times it's like double clicking, other times it repeats the last doubleclick... behavior inconsistent and confusing. It should just change the behaviour without committing any changes.
                                  I would have loved to help solve these issues myself, but scripting is Chinese to me... 😎
                                  FlexTools - Super Quick Windows, Doors, Slats...
                                  • boofredlayB Offline
                                    boofredlay
                                    Well done. Thank you.
                                    • halroachH Offline
                                      halroach
                                      I forgot to mention a very important detail. 😄
                                      I was testing the script on Mac OSX with sketchup 7.0! so all the points above relate to sketchup on OSX.
                                      testing it on a PC with sketchup 7.1 returned very nice results! Though points 2 and 3 above are still problematic.
                                      • P Offline
                                        push
                                        thank you!
                                          mics_54
                                          very cool, thanks!
                                            serena
                                            • 2 / 5
