    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 215.9k Views 65 Watching
    • david_hD Offline
      david_h
      okay . .this is total awesomenicity. Any possible way it could be written to be accessed from a right-click like JPP? That would just be cherry.
      THx,
      D
      • MALAISEM Offline
        MALAISE
        Yeee! Thanks a lot for this plugin 👍
        MALAISE
          matteo
          oooh!
          “The one fact about the future of which we can be certain is that it will be utterly fantastic” – Arthur C Clarke
          “The one fact about ruby coders of which we can be certain is that next ruby plugin will be utterly fantastic” – Matteo Bignozzi
          thank you a lot arc4tect
          hire me: http://www.nonsolo3d.it/ !
          • EscapeArtistE Offline
            EscapeArtist
            Fantastic tool. I've been wishing for something like this for a while.
            Nice job, I'm looking forward to any improvements you make.
              dtrarch
              a4
              Simply just a WOW
              Thank you
              dtr
                CADAddict
                Very nice,
                I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation?
                Great job anyways!
                http://www.cad-addict.com/
                • urgenU Offline
                  urgen
                  ...very usefull! 👍 thank you!:)
                  --pupil forever...------
                  • utilerU Offline
                    utiler
                    @cadaddict said:
                    Very nice,
                    Great job anyways!
                    I like that idea, CADAddict!
                    Maybe something similar to the standard Pushpull with 'Ctrl' Pushpull leaving original face and edges....
                    What do you think a4chitect?
                    Just Curious...
                      a4chitect
                      i think you are talking about thd first entry in the todo list in the first post; such feature is planned.
                        Tricky! ☀
                        • halroachH Offline
                          halroach
                          Great and useful Plugin!
                          I've got a few more to do's:
                          1. What makes sketchup a great and fast program to use, is mainly the easy inferencing!
                            As with the regular push-pull tool, you should be able to indicate exactly where the pulled plane will arrive to. The pulled plane should stick to existing lines/points which may intersect with it.
                          [right now, I've noticed it only sticks if I start pulling the plain from a point (which is very difficult to determine if it's sticking or not) which is on a line (perpendicular to the pulled plain) which reaches the point I want to get to... (I imagine that's isn't very clear, I can add an image if needed) ]
                          1. If two, or more of the side planes merge into a single point or a single line, it ought to stick there too.
                            geometrically that would happen when one any one of the side planes gets to n-1 edges.
                          2. when using the VCB - entering a number, pressing enter, and then entering another number, should act like other sketchup tools. It should act as though you're still pulling the same plane once. currently it keeps making more and more faces.
                          3. when pressing TAB WHILE using the tool - at times it's like double clicking, other times it repeats the last doubleclick... behavior inconsistent and confusing. It should just change the behaviour without committing any changes.
                          I would have loved to help solve these issues myself, but scripting is Chinese to me... 😎
                          FlexTools - Super Quick Windows, Doors, Slats...
                          • boofredlayB Offline
                            boofredlay
                            Well done. Thank you.
                            • halroachH Offline
                              halroach
                              I forgot to mention a very important detail. 😄
                              I was testing the script on Mac OSX with sketchup 7.0! so all the points above relate to sketchup on OSX.
                              testing it on a PC with sketchup 7.1 returned very nice results! Though points 2 and 3 above are still problematic.
                                push
                                thank you!
                                  mics_54
                                  very cool, thanks!
                                    serena
                                      boofredlay
                                      Diego, this is what you want:
                                      http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
                                        DIEGO-RODRIGUEZ
                                        I use the plugins, Joint Push Pull
                                        but not works as SmartPushPull v0.26
                                        idea for icons
                                          DIEGO-RODRIGUEZ
                                          can you add, pushpull for multiple faces?Âż
                                          maybe pressing> shift <
                                            monkeybss
                                            Very good! And in time, too.Thanks!
                                            • 2 / 5
