    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 211.8k Views 65 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Fantastic tool. I've been wishing for something like this for a while.
      Nice job, I'm looking forward to any improvements you make.
        dtrarch
        a4
        Simply just a WOW
        Thank you
        dtr
          CADAddict
          Very nice,
          I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation?
          Great job anyways!
          http://www.cad-addict.com/
          • urgenU Offline
            urgen
            ...very usefull! 👍 thank you!:)
            --pupil forever...------
            • utilerU Offline
              utiler
              @cadaddict said:
              Very nice,
              Great job anyways!
              I like that idea, CADAddict!
              Maybe something similar to the standard Pushpull with 'Ctrl' Pushpull leaving original face and edges....
              What do you think a4chitect?
              Just Curious...
                a4chitect
                i think you are talking about thd first entry in the todo list in the first post; such feature is planned.
                  Tricky! ☀
                  • halroachH Offline
                    halroach
                    Great and useful Plugin!
                    I've got a few more to do's:
                    1. What makes sketchup a great and fast program to use, is mainly the easy inferencing!
                      As with the regular push-pull tool, you should be able to indicate exactly where the pulled plane will arrive to. The pulled plane should stick to existing lines/points which may intersect with it.
                    [right now, I've noticed it only sticks if I start pulling the plain from a point (which is very difficult to determine if it's sticking or not) which is on a line (perpendicular to the pulled plain) which reaches the point I want to get to... (I imagine that's isn't very clear, I can add an image if needed) ]
                    1. If two, or more of the side planes merge into a single point or a single line, it ought to stick there too.
                      geometrically that would happen when one any one of the side planes gets to n-1 edges.
                    2. when using the VCB - entering a number, pressing enter, and then entering another number, should act like other sketchup tools. It should act as though you're still pulling the same plane once. currently it keeps making more and more faces.
                    3. when pressing TAB WHILE using the tool - at times it's like double clicking, other times it repeats the last doubleclick... behavior inconsistent and confusing. It should just change the behaviour without committing any changes.
                    I would have loved to help solve these issues myself, but scripting is Chinese to me... 😎
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • boofredlayB Offline
                      boofredlay
                      Well done. Thank you.
                      • halroachH Offline
                        halroach
                        I forgot to mention a very important detail. 😄
                        I was testing the script on Mac OSX with sketchup 7.0! so all the points above relate to sketchup on OSX.
                        testing it on a PC with sketchup 7.1 returned very nice results! Though points 2 and 3 above are still problematic.
                          push
                          thank you!
                            mics_54
                            very cool, thanks!
                              serena
                                boofredlay
                                Diego, this is what you want:
                                http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
                                  DIEGO-RODRIGUEZ
                                  I use the plugins, Joint Push Pull
                                  but not works as SmartPushPull v0.26
                                  idea for icons
                                    DIEGO-RODRIGUEZ
                                    can you add, pushpull for multiple faces?¿
                                    maybe pressing> shift <
                                      monkeybss
                                      Very good! And in time, too.Thanks!
                                      • plot-parisP Offline
                                        plot-paris
                                        that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
                                        • brookefoxB Offline
                                          brookefox
                                          I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
                                          Thanks much for sharing.
                                          ~ Brooke
                                            Panga
                                            Thanks a lot for this plugin !! Keep going !
                                            • 2 / 5
