    Random tip: A stack of logs without obvious repetition
    33 Posts 10 Posters 9.6k Views 10 Watching
    • E Offline
      Ecuadorian
      Weird. Could you please repost your model so I can have a look?
      -Miguel Lescano
        agamemnus
        Ok, here is my logs model.
        logs6.skp
        • E Offline
          Ecuadorian
          Ok, I see that the logs are intersecting between them and this seems to be causing some kind of explosion effect. Make sure to use Chris Fullmer's plugin as I described in my first post: Min scale 0.9, Max scale 1.0. If you use a higher scale the logs will start to intersect.
          -Miguel Lescano
            agamemnus
            I also tried that... maybe I am adding the geometric shape wrong. 😢 I removed everything but 1 log and it still jumped...
            Dunno.. I removed all plugins except Sketchyphysics 3RC1 and it still jumped...
            Non-intersecting logs attached...
            logs6b.skp
            • Chris FullmerC Offline
              My random scale tool seems to be causing jumping issues for some people. I have not yet looked into it 😞 Sorry if its affecting your workflow. Hopefully I'll get a chance to check it out soon,
              Chris
              All my Plugins I've written
              • E Offline
                Ecuadorian
                As far as I know, the current version does not support friction settings.
                Weird what happened to your logs...
                -Miguel Lescano
                  agamemnus
                  I went around the jumping issue by re-grouping every log individually after using "scale and rotate multiple" (whew!).
                  But now I have another question! Is there a way to add friction in Sketchyphysics? I don't want the logs to rely on the artificial "rope" -- the walls to keep them from rolling off the ground. I want them to adjust a little and then stop moving due to friction.
                  Edit: Maybe the "magnet strength"? But how do I adjust properties of all objects at the same time as opposed to individually? 😞
                  • F Offline
                    Fletch
                    here's the 'final' where I used the logs. thanks again Miguel! 😉
                    Fletch
                    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                      agamemnus
                      Wow, that looks fun. What are you using it for?
                        Had I know the intention you could have had these...logs.pnglogs.skp
                          And this is exactly the case when projected material works pretty well on the sides, too. 👍
                          • E Offline
                            Ecuadorian
                            @tig said:
                            Had I know the intention you could have had these...[attachment=1]logs.png[/attachment~
                            -Miguel Lescano
                            • F Offline
                              Fletch
                              @tig said:
                              Had I know the intention you could have had these...[attachment=1:rtt0x3zm]<!-- ia1 -->logs.png<!-- ia1 -->[/attachment:rtt0x3zm][attachment=0:rtt0x3zm]<!-- ia0 -->logs.skp<!-- ia0 -->[/attachment:rtt0x3zm]
                              😮 wow! 2 gifts in the same thread! Thanks a ton, TIG!
                              You can see the 'final' image in the House and Pool thread (using Miguel's logs, I didn't see your component here 'til just now. 😢
                              Fletch
                              • 2 / 2
