    Random tip: A stack of logs without obvious repetition
    33 Posts 10 Posters 10.5k Views 10 Watching
      agamemnus
      @ecuadorian said:
      I have just described the exact process for copying them in an array, and in the first page I gave the instructions to randomly rotate and scale them. You have to do all this while the logs are in a vertical position, before positioning them for SketchyPhysics.
      I didn't see your last post. 😠
      Edit: I see. Your original model looked a little more randomly positioned. I guess all the different sizes make it look that way.
      I manually made a few logs (30 or so), but they are jumping up outwards in the first frame (even though they are close to each other) so they end up all displaced towards the end. I'll try an equally-positioned set and see what happens.
      Edit 2: Yes, jumping out again. Some falling through the catching mesh. Not sure what to do. Maybe not enough polys per log?
      Edit 3: Used the same log model as yours (increased the size a bit), but still jumping.
      • E
        Ecuadorian
        Weird. Could you please repost your model so I can have a look?
        -Miguel Lescano
          agamemnus
          Ok, here is my logs model.
          logs6.skp
          • E
            Ecuadorian
            Ok, I see that the logs are intersecting between them and this seems to be causing some kind of explosion effect. Make sure to use Chris Fullmer's plugin as I described in my first post: Min scale 0.9, Max scale 1.0. If you use a higher scale the logs will start to intersect.
            -Miguel Lescano
              agamemnus
              I also tried that... maybe I am adding the geometric shape wrong. 😢 I removed everything but 1 log and it still jumped...
              Dunno.. I removed all plugins except Sketchyphysics 3RC1 and it still jumped...
              Non-intersecting logs attached...
              logs6b.skp
              • Chris FullmerC
                My random scale tool seems to be causing jumping issues for some people. I have not yet looked into it 😞 Sorry if its affecting your workflow. Hopefully I'll get a chance to check it out soon,
                • E
                  Ecuadorian
                  As far as I know, the current version does not support friction settings.
                  Weird what happened to your logs...
                  -Miguel Lescano
                    agamemnus
                    I went around the jumping issue by re-grouping every log individually after using "scale and rotate multiple" (whew!).
                    But now I have another question! Is there a way to add friction in Sketchyphysics? I don't want the logs to rely on the artificial "rope" -- the walls to keep them from rolling off the ground. I want them to adjust a little and then stop moving due to friction.
                    Edit: Maybe the "magnet strength"? But how do I adjust properties of all objects at the same time as opposed to individually? 😞
                    • FletchF
                      Fletch
                      here's the 'final' where I used the logs. thanks again Miguel! 😉
                      Fletch
                        agamemnus
                        Wow, that looks fun. What are you using it for?
                          Had I know the intention you could have had these...logs.pnglogs.skp
                          • GaieusG
                            And this is exactly the case when projected material works pretty well on the sides, too. 👍
                            • E
                              Ecuadorian
                              @tig said:
                              Had I know the intention you could have had these...[attachment=1]logs.png[/attachment~
                              -Miguel Lescano
                              • FletchF
                                Fletch
                                @tig said:
                                Had I know the intention you could have had these...[attachment=1:rtt0x3zm]<!-- ia1 -->logs.png<!-- ia1 -->[/attachment:rtt0x3zm][attachment=0:rtt0x3zm]<!-- ia0 -->logs.skp<!-- ia0 -->[/attachment:rtt0x3zm]
                                😮 wow! 2 gifts in the same thread! Thanks a ton, TIG!
                                You can see the 'final' image in the House and Pool thread (using Miguel's logs, I didn't see your component here 'til just now. 😢
                                Fletch
                                • 2 / 2
