    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      AcesHigh
      why arent these coplanar faces (from two different GoogleEarth imported meshes) merged?
      http://img6.imageshack.us/img6/8480/coplanarfaces.jpg
      in this thread, I first tried to use the 2D Boolean plugin. To no use, as we can see here. There are still plenty of coplanar faces where the GoogleEarth imported meshes overlap.
      http://img266.imageshack.us/img266/5064/coplanarfaces2.jpg
        Can you post the model?
        Also, what are your settings? Remember that CleanUp has options to take into account face normals, material and UV mapping when merging.
        Also, that image seem to illustrate faces occupying the same plane...?
          AcesHigh
          no need to upload the model. It happens with any model, when importing several GoogleEarth meshes which overlap.
            Well, I don't see the behaviour, so if I am to check this out I need something to work with.
            And these meshes, do you merge them into one group?
              AcesHigh
              sorry ThomThom, it had happened in every experiment I did before, so I wrongly assumed it would happen in every one. But I did one try with two small pieces and nothing happened (although there were some lost textures in the process)
              So I will upload a SKP file. Thanks for the patience and hard work.
              yup. Merge them into one group, then explode the meshes inside the group. Then CleanUp them. In the file I am sending you, not only some faces were lost when using CleanUp, as some coplanar faces were not merged, so you can see some texture flickering when rotating around.
              experimento2.skp
                  That model is after CleanUp is run? You got the original?
                    AcesHigh
                    what settings ThomThom? The ones from CleanUp³?
                    everything selected except Geometry to Layer 0, Merge Identical Materials (its two different materials, a bitmap for each imported mesh), so I saw no reason to use it) and Erase Stray Edges.
                    sorry, I didnt keep the original imported meshes. But I will try again with new imported meshes.
                      Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
                        AcesHigh
                        here... I copied the two meshes and joined them in a group, exploded them, and used Cleanup. No lost triangles this time, but there are plenty of overlapping triangles. (sometimes they dont appear when viewing in the textured mode, but when you used SHADED mode you will see the overlapping triangles...)
                        of course, the problem gets worse when you have to import even more mesh pieces, as sometimes you have over 3 meshes overlapping.
                        experimento3.skp
                          AcesHigh
                          I will try that, thanks... however... how can I intersect if they are not solids?
                          ps: I am trying to solve, with CleanUp, about the same problem that made me ask for the "GoogleEarth Meshes boolean subtract" plugin at the topic http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
                            Not intersecting with Solid Tools, but the regular intersect that's been in SU since, ever..? From the context menu, there is Intersect Faces menu item.
                              AcesHigh
                              since ever, but I had never seen or used it before 😆
                              anyway, however, intersected it with itself several times, and when I used cleanup³, several triangles were lost, and got some error messages 😢
                                What where the error message?
                                  AcesHigh
                                  something along these lines (not exactly the same because I had to test again, with new Earth imported meshes, so different triangles disappeared, etc)
                                  Results of Validity Check.
                                  CEdge (4234) and CEdge (7926) connect the same 2 vertices - fixed
                                  The plane equation for CFace (4767) is not valid - fixed
                                  35 errors occurred. Please report the error and sample model to the author.
                                  35 - Face merge resulted in lost geometry!
                                  • sumasterS Offline
                                    sumaster
                                    Dear Thomthom Sir,
                                    here you are launch your new Cleanup (3.1.8) — 06 October 2011
                                    • Whats new features you are added ❓
                                    and one problem can you solve in new version
                                    I'm architectural student and import CAD drawing and lock that drawing in sketchup viewport
                                    but when i play / start " Clean With Last Setting " he also cleanup viewport with lock group/component 😮
                                    See here ......
                                    Regular selection
                                    Lock selection
                                    Finally clean every thing .....
                                    And thank you for this tool its very best for me or ever one ...... 😄 😉
                                    I'm very happy with this tool ......
                                    Thank you,
                                    SUmaster
                                      The way CleanUp traverses the model it's tricky to know what is part of a locked group or not. But I'll put it down for investigation.
                                      • sumasterS Offline
                                        sumaster
                                        Yes thank you .....
                                        Thank you,
                                        SUmaster
                                        • dereiD Offline
                                          derei
                                          You can use ruby to check if is locked or not
                                          http://code.google.com/apis/sketchup/docs/ourdoc/group.html#locked?
                                          http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#locked?
                                          DESIGNER AND ARTIST DEREI.UK
                                            I know, but, I traverse the model by model.definitions.each - which means that I do not know if the parent for the instances I traverse are locked. I could be checking a sub-group of a locked group and .locked? will return false.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 48
                                            • 49
                                            • 24 / 49
