    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 67.5k Views 42 Watching
    • mitcorbM Offline
      mitcorb
      Kirill:
      While testing, I am seeing the commands Interact with cpoints and Deform face interactive. The selection of the points is difficult because all I have is a pointer. It would be good to do a small selection box on the point. Is the deformation guided by a single point or multiple points? I am using construction points from D. Bur's Projections Toolbar.
      I think this ruby needs a parameters interface so that the degree of influence can be selected and or edited. Maybe a PDF of instructions or proper procedure if not the parameter interface.
      Edit: Please note. Deleted erroneous Ruby Console excerpt. May have been a miss keyed right click context menu selection. If you viewed this post previously, please disregard those contents. Edit
      • K Offline
        kirill2008
        I was going to make a pointer apperture size bigger (don't know how yet) and process 'all_picked' entities instead of 'best_picked' method to find c-points. In short, I'm currently trying to make selection process easier.
        Geometry group deformation takes in account all control c-points. Curve deformation takes in account the selected point and its 2 adjacent neighbours.
        It is possible to select a set of existing construction points and then pick geometry group to make them control c-points for the picked group (Select c-points, right-click and choose 'Select a group to be under control...' command from the context menu).
        Well, yes, actually script became a bit more complex and unfortunately less intuitive, so I agree it requires now some kind of documentation or more detailed instructions.
        Currently it is possible to affect the degree of influence of geometry group control c-points while 'Interact with control points...' command is active by hitting <up-arrow> and <down-arrow> keys, when the c-point is selected or under cursor.
        • mitcorbM Offline
          mitcorb
          Kirill:
          You wrote "Geometry group deformation takes in account all control c-points." This says that I must group the cpoints. You further suggest that the construction points I was using are not the source. I am getting no prompt to input any other cpoints, and I am unable to influence more than one poly at a time during deformation.
          Does the entire mesh need to be peppered with cpoints? In your video, I don't see this, and yet you are able to affect the whole mesh?
          I cannot access curve deformation?
          I cannot adjust power, as seen in the bottom line prompt.
          I am obviously doing something wrong, or missing a prompt.
          • X Offline
            xrok1
            just noticed 1.6 😮 😲 😍
            i agree about locking edges, BTW.
            “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • K Offline
              kirill2008
              The new idea came, what if we use control boxes instead of control points.
              It will allow scale and rotation changes tracking (construction point gives possibility to track only offset from its previous position).
              Set of videos shows beginning of mentioned idea implementation (scale tracking doesn't work yet):
              [flash=480,385:s0yxbjzt]http://www.youtube.com/p/E7A33957B617B9AF&amp;hl=ru_RU&amp;fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:s0yxbjzt]
              I think it will be more 'natural' and easy to use interaction way. I think, I'll add 'power' value of control boxes adjustment in the context menu maybe.
              I also agree about edges locking and I think it's possible.
              • jason_marantoJ Offline
                jason_maranto
                😲 Whoah --you are definately way too good at this... can't wait to play with that.
                best,
                Jason.
                • EarthMoverE Offline
                  EarthMover
                  Great Idea with the boxes Kirill! The point painting is also really cool and I expect lots of colorful posts from Pilou using it! Also good to hear you are working on an outer edge lock. 👍
                  Content Creator at Skapeup
                    malakon
                    I'm having problems with this plugin and it seems that is not only me, here is a link to a user in the forum with the same problem
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=25722&p=222893#p222893
                    Control Points causing SU 7 to crash
                    Postby aswiger on Tue Feb 02, 2010 4:20 am
                    I am using the Control Points plugin, and there seems to be at least a couple issues when following along in some of the youtube videos posted by the plugin's creator. First, whenever I add control points then use the move tool to move one of the points, SU will give me an odd error message: "most probably geometry group was erased", then crash.
                    Also, when I draw to circles and select both, the blend option is not visible on a right click. I've restarted my machine, re-installed the plugin, tried using both 1.6 and 1.7 to no avail. I'm using SU 7.1 pro on Windows 7. Any advice? Thanks!
                    Aaron
                      apple85
                      @kirill2008 said:
                      @wind-borne said:
                      i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
                      As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
                      So I'll try to make the script more tolerant to the selection in future versions 😄 .
                      Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
                      I got a similar problem to the above - i try selecting the lines around a simple 2d shape like a circle, triangle (like in the original first video at the beginning of this thread) - just the lines and not the 2d face but when i right/control click i do not get the 'Add control points to the curve' option to start off the whole process with this plugin. I think my sketchup knows that it exists as as another user on this forum pointed out to me, in the 'plugin' menu there are 4 modify options to do with this plugin, i just can't use them until i have figured out how to add the control points. i've tried selecting the both 2d and 3d shapes and right clicking but there is still no control point option.
                      if someone could point out where i'm going wrong or give me a brief step to step on how to add the control points to both 2d and 3d shapes, it would be a massive help!
                      curve control points.pdf
                      • X Offline
                        xrok1
                        well this deserves a bump anyway but also i have a problem. if i draw a cirle, right click add cpoints every 3rd, now when i go to move a point up iget this message followed by a bug splat everytime. 😞
                          August
                          I'm having no luck getting started with this. I suspect that I'm missing some changes in the directions for how to get started, but I'm pretty sure that I at least skimmed the whole thread.
                          1. Download and install the v1.6 script from the first post.
                          2. Open SU, create a test object (3D text my favorite for testing this kind of thing).
                          3. Plugin Menu has four new items, but they all appear to need c-points already added.
                          4. Right click (context click) on the group --
                            No new menu items, nothing mentioning c-points, the options suggested at various points in the thread (I don't know for sure that I've found the most recent) are not there.
                          Any pointers to what steps I'm missing?
                          Thanks,
                          August
                          P.S. Windows 7, SU 7.1.6860
                          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                          • X Offline
                            xrok1
                            right click on a group (has to be a group)
                              August
                              @xrok1 said:
                              (has to be a group)
                              Thanks. I "thought" it was, but 3D text gets created as a component, not a group. Explode and regroup and the menu options are are there!
                              Thanks,
                              August
                              • X Offline
                                xrok1
                                got me the first time i tried this plug on 3dtext to solve your insane problem too. 😲
                                (yes i'm still thinking about it. 👿 )
                                  August
                                  As I said, don't hurt yourself. I have a workaround.
                                  For me it's now at the level of how to make these amazing tools even more insanely flexible while still keeping them intuitively useful. Maybe one of the extension ideas I throw out will stick to one of the developers the way this question seems to have stuck with you.
                                  August
                                  • N Offline
                                    notareal
                                    What happened to videos? 😕
                                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                    • K Offline
                                      kirill2008
                                      If someone still interested in this plugin, then, I guess, this video will be interesting too:
                                      [flash=560,315:38wj9eza]http://www.youtube.com/v/dXHJSEXn86Y?version=3&amp;hl=ru_RU[/flash:38wj9eza]
                                      • mitcorbM Offline
                                        mitcorb
                                        Yep, the video is interesting. I may have to watch it another couple of hundred times until my little brain can fully grasp what all you did here.
                                        • K Offline
                                          kirill2008
                                          @mitcorb said:
                                          I may have to watch it another couple of hundred times...
                                          200 views per one viewer, that's how I'll finally become popular on YouTube 😆
                                          in 'science/technology' category I mean 😄
                                          Actually I was trying to keep things simple, but it looks like I have to try more efficiently... Because it is still not obvious for end user, how everything works 😕 . The final goal is to make tool processing so intuitive that one would not need to watch tutorial 200+ times 😄
                                          • mitcorbM Offline
                                            mitcorb
                                            Well, you know I was joking. Actually, on a second viewing, and with more time to watch it through, the concept was clear enough. The details- commands, tool selections, sequence and so forth will take a little longer for me.
                                            However, on one viewing, it is clear that this is a significant development. Congratulations. 👍 👍
                                            • 6
                                            • 5 / 6
